EBC brake Pads
Ordini effettuati da soci del club tramite GroupBuy
EBC brake Pads
Messaggio da luchetto » lunedì 27 agosto 2007, 21:26
Volevo qualche info + dettagliata e veritiera su chi ha montato queste paste,sopratutto se venite da pasticche nn stock,in modo da confrontarle con altre marche.
Sarei propenso a questo modello
Coefficente d'attrito 0.5
Superstreet formula for cars above 200bhp and fastest street driving
This material is a Kevlar? fibre based brake compound enhanced with ceramic particles. If you have previously tried EBC redstuff (pre-ceramic compound) this material is light years ahead. It lasts longer, it brakes better and is quieter. Being a hard wearing pad, bed-in times can be as long as 1000 miles and drivers must be patient until the pad takes up the shape of their disc (brake rotor).
This is a truly impressive fast road pad for repeated heavy braking. It emits far less dust than semi-metallic pads and has been proven to stop a passenger car/sedan/sport compact/hot hatch 13 metres quicker than OEM pads from 100mph/160kph. Features EBC Brake-In surface coating which conditions rotor surface and accelerates pad bed-in. Nominal friction coefficient 0.5 with approx. 50% dust reduction compared to other pads.
Most EBC Red Ceramic pads are approved to ECE R90 brake safety regulation
poi ci sono le gialle
Although a full race material and capable of high temperature use with very good wear life, this new formulation sets a new trend in race type brake pad compounds that can be used on the highway. The ?bite? from cold is superb which is uncommon with race materials (normally requiring warm-up) and makes this a pad which can be safely used on both street and track. This new formulation has been used by numerous championship race and rally drivers and is truly a milestone in brake pad material development. Nominal friction coefficient 0.5 with zero rotor damage and similar dust to original pads.
Many part numbers now carry ECE R90 approval. Check with our technical department on technical@ebcbrakesuk.com to confirm if this material is street legal for your model when using for highway driving within Europe where regulation 90 applies. Outside Europe just fit and enjoy, these pads are the grippiest and most impressive pads that you will have ever used. Click here for more information about ECE R90 brake safety regulations.
con coefficente 0.5
e le blu
con coefficente 0.40
EBC Bluestuff is the longest lasting of the EBC brake pad materials family and is designed for heavier and faster sedans/passenger cars/muscle cars in track use.
Bluestuff has a nominal friction coefficient of 0.40, good temperature stability up to 750?C (1300?F) and higher, with significant lifetime making it capable of withstanding 3-5 hour duration races.
Bluestuff material has been used successfully on larger Porsche cars in racing and such as the Emotional Engineering Monaro competing in the British GT Championships and FIA GT World Championships.
The material has also found great success being used on the Drivers Dreamdays which includes Ferrari cars, Subaru and Lamborghini.
Considerate che ho sempre montato le ferodo DS2500 xchè vado in pista un 3/4 volte l'anno,quindi la CTR vene usata x il 75% su strada.
Voglio una pasticca che nn mangi i dischi come la DS3000 ,quindi un compromesso ma che sia cmq superiore alle 2500 :good
Messaggio da zan » lunedì 27 agosto 2007, 23:31
che io sappia le ha provate Mick Doohan su EP3, non so però quale modello di preciso, penso le gialle...
Messaggio da Toro-R » lunedì 27 agosto 2007, 23:36
vai di DS 1.11 :teach
Furious
Messaggio da Furious » lunedì 27 agosto 2007, 23:57
verdi=poco + che stradali
rosse =2500
gialle=3000 ma mangiano meno i dischi
blu=3000endurance
"Tu tira o resta a casa"
Messaggio da Mick Doohan » martedì 28 agosto 2007, 9:02
io ho usato le verdi, e venendo dalle stock il miglioramento è stato tangibile, un a buona pastiglia stradale. Poi sono passato alle DS2500 e devo dire che la differenza (in meglio) rispetto alle EBC verdi si sente soprattutto in pista. Le EBC a spanne dovrebbero durarti qualcosa in più rispetto alle DS2500. Ora che ho provato le DS2500 posso dire che in pista DS2500>EBC verdi, in strada sono equivalenti, col difetto delle DS2500 di fischiare a freddo.
Visto che hai già montato le DS2500, e vuoi provare le EBC andrei su qualcosa di più performante rispetto alle verdi (IHMO).
AieieVTEC
Messaggio da AieieVTEC » martedì 28 agosto 2007, 9:45
Vai direttamente sulle gialle!
Costano un pelo meno delle rosse(anche se non ho ancora capito bene perchè) frenano molto(un pelino meno delle DS3000) duramo molto(mooolto di più delle DS3000) e non distruggono per niente il disco!
DanielM Docet! :teach
Messaggio da manzo » martedì 28 agosto 2007, 10:22
Messaggio da gesus » martedì 28 agosto 2007, 10:55
io ho le rosse e van benone, la durata in effetti sembra molto buona e la frenata anche ...
non so, penso che se dovessi riprendere il set forse mi butterei sulle gialle visto quello che ha scritto aieie...
ordina dall inghilterra che hanno buooooooni prezzi :teach
Messaggio da luchetto » martedì 28 agosto 2007, 13:14
Gesus infatti il contatto che ho ? dall'UK
Come dice AIEIE proverò la gialle se solo quel negoziante si degnasse di rispondermi :rant
Cmq grazie...ero indirizzato sulle rosse,ma ora ho le idee + chiare :D
civic4ever77
Messaggio da civic4ever77 » martedì 28 agosto 2007, 14:06
Anch' io ero per le rosse perchè sapevo che le gialle erano più aggressive con il disco e meno prestazionali " a freddo". Ma se Aieie dice così, quasi quasi provo le gialle :good
Si fa GB?!
Messaggio da luchetto » martedì 28 agosto 2007, 17:20
Civic se vogliamo fare un GB vediamo un'attimo tutti i costi e poi ci mettiamo daccordo.
DINO
Messaggio da DINO » martedì 28 agosto 2007, 19:07
Daniel monta le pinze SPOON,farei una comparativa con una pinza stock sinceramente..
Messaggio da luchetto » martedì 28 agosto 2007, 21:30
Aieie,ho letto che ci sono le yellow vecchie e nuove oltre che le R
Sono questi i codici ,giusto?
DP41254 Front Pad
DP41254R Front Pad
Conosci la differenza tra le 2?
thanks
AieieVTEC
Messaggio da AieieVTEC » martedì 28 agosto 2007, 22:44
luchetto ha scritto:Aieie,ho letto che ci sono le yellow vecchie e nuove oltre che le R
DP41254 Front Pad
DP41254R Front Pad
thanks
Io ho sempre preso le R, il prezzo non cambia...
Per il codice devo controllare, ti faccio sapere....
civic4ever77
Messaggio da civic4ever77 » mercoledì 29 agosto 2007, 8:15
luchetto ha scritto:Civic se vogliamo fare un GB vediamo un'attimo tutti i costi e poi ci mettiamo daccordo.
Ci sto. Fammi sapere :good
streetracer
Messaggio da streetracer » mercoledì 29 agosto 2007, 8:31
tenetemi informato per il GB a limite io prendo le RED ma se dite che le yellow non mangiano i dischi piu di tanto prendo quelle
http://www.rotaryheaven.net/
civic4ever77
Messaggio da civic4ever77 » mercoledì 29 agosto 2007, 10:59
streetracer ha scritto:tenetemi informato per il GB a limite io prendo le RED ma se dite che le yellow non mangiano i dischi piu di tanto prendo quelle
La mia intenzione è la stessa :good
Messaggio da luchetto » mercoledì 29 agosto 2007, 14:44
sto acnora aspettando,mi ha contattato anche un'altro ragazzo x le EBC,quindi potremmo essere in4
Appena so qulcosa x le SS se facendo un pacco cumulativo la spesa resta identica meglio ancora.
Messaggio da luchetto » mercoledì 29 agosto 2007, 16:40
risposto...
22? x la spedizione,in cui possono entrare 10 paia di pasticche.
Ora aspetto il prezzo delle EBC...poi si inizia...
ho chiesto un preventivo x paste DC - EP3 - S2K
DINO
Messaggio da DINO » mercoledì 29 agosto 2007, 20:05
luchetto ha scritto:risposto...
Per tutti i colori?
