Our Honda Civic was built to display our ability, skills and experience in the tuning industry. The car was cover featured in Banzai Magazine, read the full article here.
Vehicle Specification
Fuel System
AEM Fuel Rail, AEM Fuel Regulator, RC 750cc Injectors, Sytec Fuel Filter, Facet Red top fuel pumps X 2, Bosch 044 Fuel Pump, 500BHP Swirl Pot, Custom Alloy Fuel Cel,l Braded Fuel Lines throughout -10 Fixtures
Electronics
Defi Boost Guage Defi Oil Pressure Guage Defi Oil Temp Guage Defi Water Temp Guage Blitz SBD Spec S Boost Controller AEM ECU MSD Distributor MSD Ignition Amplifier MSD Coil
Engine
B18C4 Block Benson Sleeved, Pauter Rods, CP Pistons 9.0 : 1, ARP Rod Bolts, Micro Polished Crank, ACL Race Bearings, OEM Head Gasket, ARP Head Bolts, B16A2 Head, Supertech Valves 1mm oversized, Supertech Valve Springs, Supertech Titanium Retainers, B18C4 Cam Shafts, Uprated Oil Pump, Modified Oil Squirters, Baffled Sump, Mocal Oil Cooler, Mocal Remote mount oil filter, B16A2 Inlet manifold, Full race pro am Exhaust Manifold, GT series TURBO, Tial 44mm Waste gate, Tial Blow off valve, Hyperflow Front mount intercooler, True 3” custom exhaust and downpipe, Mishimoto Half Size radiator, Custom Turbo radiator, HASPORT Engine Mounts.
Transmission
S9B Gearbox, Shot Peened Gearset, Quaife ATB, Driveshaft shop 2.9 Axles, Clutchmasters Clutch, Clutchmasters 7.5lb Flywheel.
Interior
OMP Bucket Seats, OMP Roll Cage, OMP Steering Wheel, TRS 5 point harnesses, Fully seam welded shell, Flocked modified Dash, Fully striped interior, Custom Braces, Custom Battery Tray.
Exterior
Aerocatch bonnet catches, Carbon Tailgate, 4mm Plastic Windows
Suspension
Koni Coilovers, Powerflex polly bushes.
Power
Dyno Dynamics 500 Flywheel BHP
Power to weight Ratio 555BHP Per TON
Power to weight Ratio of Bugatti Veyron 521BHP Per TON
