EP3: Lineare? Progressivo? Camber? Coverg.? Incid.? SilentB?
Ubaldo
Messaggio da Ubaldo » martedì 22 marzo 2005, 10:28
C[...]O !!! (censura)
Ma è perfetto !!!
Tre valori di caster e camber a regolazione continua !!!
Notissie, notissie, notissie ...
... sbav, sbav ...
:p
Tenshi
Messaggio da Tenshi » martedì 22 marzo 2005, 10:34
facciamo un GB ?? :strama
typer558
Messaggio da typer558 » martedì 22 marzo 2005, 10:40
maledette testine di testicolo che non siete altro!!! :rant :rant :rant
Ho postato il link una settimana fa e manco ve lo siete inculato de pezza e ora mi chiedete raggggguagli????? :sosp :sbonk
Cosa vi dovrei rispondere ora?????
:sifone
http://forums.clubrsx.com/showthread.php?t=237093 :strama :scree
When I learned that the RSX had 1.5 (+/- 1) deg. positive caster I had to do something about it. (So the car could have only 1/5 deg of caster in still be in spec.)
So here it is, caster/camber plates that replace to camber plates at the top on my Endless Zeal coilovers. I did make two sets so I have one available. I am not sure they will fit other brands of coilovers.
The plate add up to 4 deg positive camber. We finished the install today and while it was on the digital alignment machine we turned the wheel and watched the inside wheel go from 2.5 deg negative camber when the wheel was straight ahead, to positive camber with the wheel turn little more than half way. This is one of the things that makes caster so cool. On hard turns you get more negative camber on the outside wheel and positive camber on the inside wheel. You achieve a bigger tire contact patch on both wheels. Goodbye understeer.
This is a view from the top. The camber is still adjustable by rotating the bottom plate. There is room to go from positive camber to 3+ deg negative camber. If I could get the coilover manufacturer to work with me, we could easily achieve another two degrees of camber, but the top of the strut would have to be a little shorter. That was my limiting factor.
Ubaldo
Messaggio da Ubaldo » martedì 22 marzo 2005, 10:47
:sosp
Ora, come una settimana fa, da quel link non riesco a vedere una ... niente.
(maledetta censura)
Allora in pole position, continua a rimanere il K-Mac.
A meno che, qualcuno non conosca chi possa fare una piccola produzione di quell'oggetto.
Sinceramente, non dovrebbe essere difficile, visto che basta disegnare bene la forma in due dimensioni.
typer558
Messaggio da typer558 » martedì 22 marzo 2005, 11:21
Uhè, sto tizio è davvero forte!!! :shock :good
http://www.teamspirit.net/rsx/ :clap
Si è fatto tutto da solo "custom" e oltre ai camber/caster plates ci sono un sacco di cose interessanti!!! :teach
Dateci un occhio che il sito funziona! :strama
Ubaldo
Messaggio da Ubaldo » martedì 22 marzo 2005, 11:26
Unfortunately they will only fit Endless Zeal coilovers
:rant
typer558
Messaggio da typer558 » martedì 22 marzo 2005, 12:11
ma guarda che mi sa che con l'assetto progressivo non troverai mai un plates del genere (solo assetti lineari a ghiera) :teach
Col progressivo mi sa che devi intervenire sul fusello con i bulloni, come facciamo noi:good
Ubaldo
Messaggio da Ubaldo » martedì 22 marzo 2005, 12:28
Mah, non credo sia importante lineare o progressivo. Più che altro sembra richiedere il montaggio di un coil-over a molle strette (che possono essere lineari o progressive o lineari+helper)
A questo punto io continuo ad appoggiare i K-Mac.
Tra l'altro sembra fatto in modo da accogliere le spire del mollone di serie.
Messaggio da MOTORPUNX » martedì 22 marzo 2005, 13:33
Si potrebbero disegnare e far tagliare al laser ma per rilevarli occorrerebbe smontare tutto (poi bisogna vedere se funziano) :angel
Messaggio da Acid » martedì 22 marzo 2005, 13:43
se volete posso farlo io. basta che mi fornite tutte le misure precise e le faccio sulla fresa cnc.
edit
x i prezzi nn saprei cosa dirvi, visto che è l'azienda dove lavora mio padre. mandatemi un disegno con tutte le misure dettagliate (quindi, occhio alle tolleranze) e vi faccio fare un preventivo a prezzo praticamente di costo. nn vi dico nulla adesso xkè mi serve una idea di misure materiale, diametri fori, tolleranze, ecc...
avete una idea di quale materiale si potrebbe utilizzare?
Messaggio da eTiLiKo » martedì 22 marzo 2005, 14:04
Rimanendo nell' "economico" credo acciaio....o duralluminio....
Messaggio da Acid » martedì 22 marzo 2005, 14:18
direi che acciaio nn sia una buona scelta, x la possibilità di arruginire o come cacchio si iscrive... inox nn ci penso neanche... costa un botto ed è merdoso da lavorare, ci metterei + ore a farlo...
forse duralluminio, ma nn ha degli "sforzi" quel pezzo lì? direi che ad occhio sarà da 7 a 10mm di spessore, un pò fragile... x sopportare il peso di una macchina ad esempio, poi, forse sparo caxxate e quello funziona solo come regolazione e basta... :imba
Ubaldo
Messaggio da Ubaldo » martedì 22 marzo 2005, 14:36
Mah, io mi stavo ponendo un altro tipo di problema.
Quella piastra è assolutamente rigida. Temo trasmetta alla scocca delle sollecitazioni pazzesche nell'uso quotidiano su fondo sconnesso.
Sbaglio?
Deg53®
Messaggio da Deg53® » martedì 22 marzo 2005, 14:39
:azz
Ubaldo
Messaggio da Ubaldo » martedì 22 marzo 2005, 14:45
:ehm
... non ho capito l'ultima parola ...
Engo
Messaggio da Engo » martedì 22 marzo 2005, 15:06
Deg53? ha scritto::azz
:roll :roll :roll
e' tornato :amore
Deg53®
Messaggio da Deg53® » martedì 22 marzo 2005, 15:38
tante cose carine e simpatiche...
però la prima distinzione tra "assetto progressivo" e "assetto lineare" è quantomeno GROSSOLANA e IMPRECISA...
per non parlare del fatto che tra l'altro la terminologia utilizzata è INESISTENTE! :azz
Ubaldo
Messaggio da Ubaldo » martedì 22 marzo 2005, 15:43
:fiush
Pensavo peggio ...
typer558
Messaggio da typer558 » martedì 22 marzo 2005, 15:46
Uba, sai che sollecitazioni che prende quella piastra??? Meglio non rischiare con materiali a casaccio.....................altrimenti va a finire che aggiungiamo un'altra CTR alle fantomatiche che perdevano le ruote........ :strama
Ve lo ricordate??? :shock
Ubaldo
Messaggio da Ubaldo » martedì 22 marzo 2005, 15:51
:nono
Pensiamo alla salute.
