CTR: PHASE intake manifold adapter!! ( 1
- typer558
Il vostro "throttle response" non vi soddisfa???????
E, allora, ecco una semplice soluzione!
It is the adapter which increases the inhalation air capacity of the intake manifold chamber substantially, but it is the part which increases the preeminent response the geta the ?? ??, due to increasing the capacity of the air in the genuine cover where is the intake manifold only of DC5 EP3.
* The intake manifold adapter is the part just a little you have not seen, but the effect is preeminent.
When adopting the fresh air, as for the effect is rising as known. When the race/lace car and the like is sucked from the funnel of the slot, in the same way, the response of the accelerator improves rapidly the air with adopting the fresh air efficiently. Principle being simple, is the part which being attached is improved with raising the capacity of the intake. When it is the other part, it becomes the method large aperture conversion of the throttle body the similar way, but when it is this method, also the part to be cheap the extent whose is simply structure simple is good, don't you think? is. It can put out power more with both combination, probably will be. Also burning pitch is the sufficient range with the study of normal ECU.
* Because it is commuting specification, also fuel economy is important. The throttle is normal. (Laughing)
* Seriously, honest word uninformed, expectation had not done, but installing, seeing, the response from when 5500 turning is good enormously. It is and it is the feeling which is sucked into red zone in the ?? coming. Just a little just opens the accelerator bodily sensation it is possible from partial for the car to keep appearing in before.
Well, being not to be different from normal because throttle opening is narrow it does, also fuel economy as a commuting car, but both torque power the foot just is placed in the accelerator lightly to call, it runs smoothly with feeling.
* Circuit travelling verification
Have excluding the downhill, almost 4th gear to finish be able to blow with ?? straight, with it was the brake point, but this time it enters into 5 speeds before the straight brake pointing. Being not to be good conditionally under any condition, it does, but as for being estimated whether startup response improvement from the corner when, to applying, thinking, it is. When speed of straight rises, this time burden falls on the brake. Being good being bad. As for influence of the part that you think whether it is, but air temperature is high result, has not extended time. How it is appraised, please presume from contents.
The photograph above makes the geta wear, capacity of the air where this amount is sucked into the intake is made. It is this much part which passes but don't you think?. The effect is preeminent
* The top expanding the aperture here with the throttle, enlarging inhalation, the large aperture throttle body. It is the tuning part which until now is.
* When the right has installed ?C???}?j?A?A?_?v?^?[.
Because the part to be cheap also the effect is preeminent, just a little it is the ?X?X??item.
COPACABANA39
Azz !!!!!!!!! Ma serve ad aumentare il volume nel collettore d'aspirazione consentendo una miglior risposta nei transitori apri/chiudi del gas ????
Geniale
_______________________________________
Salumi CopaCarni ...... l'arte della prosciutteria
Geniale
COPACABANA39
Dimenticavo ............. lo voglio
Se ti stai informando per prenderlo considerane due
- typer558
COPACABANA39
Se riesci a capire ESATTAMENTE l'altezza dello spessore posso farlo io ad un rpezzo ridicolo
Se ti piace l'idea ci mettiamo all'opera
- typer558
COPACABANA39
Perfetto, allora prendi i coll e spalma sulla battuta dell'inchiostro (che dopo pulirai con alcool denaturato) per poi imprimere la battuta stessa su un foglio A4 (come se fosse un timbro).
A quel punto prendi calibro e righello di precisione e mi quoti il pezzo, l'interasse delle viti, la sezione dei fori.
Prendi l'A4 quotato e lo scanerizzi o gli fai una foto e me la mandi in email ...............
Per quando ci vediamo ti porto lo spessorone
- typer558
COPACABANA39
Ok
Visto che cavolo di cose ci sono su quei siti ??
Hai visto qui www.macfarm.org/KAZU/car/dc5/track3.html
E come caxxo si imbratta il collettore di aspirazione qui
www.macfarm.org/KAZU/car/dc5/oil_1.html
p.s.
la motul và forte in giappo
p.s.
HDriver
ahaha i nostri due scienziati-pionieri pazzi
Explanation of suspension's bounce and ri-bounce.
andre@absoluteJDM.tk<i></i>
- typer558
Quote:Hai visto qui www.macfarm.org/KAZU/car/dc5/track3.html
E secondo te da dove ho preso spunto per comprare le IK24????
Piuttosto, se ti piacciono i siti jappo di EP3, visita questo di un mio amico del sol levante. PS Guarda soprattutto i BBS e i Link
Clicca il mio Amico Jappo!!
void
COPACABANA39
A priori sembra una cazzata ..........
Ma se ci pensi bene aumentare il volume del collettore d'aspirazione non è una cazzata, sopratutto quando come nel caso di Typer, il motore è configurato per ciucciare un quantitativo d'aria molto superiore rispetto allo stock
void
aumentare il volume (tra l'altro non in un punto in asse con le trombette di aspirazione) mi pare controproducente in termini di turbolenza del flusso...
e sappiamo quanto possa contare lì ... quel polmone lo vedo un po' gianni spec...
poi per carità, finchè non lo si prova...
inoltre c'è un'altra cosetta da dire... il volume del coll di aspirazione è sicuramente importante, ma se è strozzato da un corpo farfallato (e ancora più probabile, dall'intake di aspirazione) allora non ne vedo proprio l'utilità.
per carità, magari il coll d'asp del k20 ha un volume insufficiente e con la sua particolare conformazione possono esserci benefici da una modifica del genere... questo di certo non posso essere io a dirlo... ma così a naso non mi pare un gran chè.
Veneto goes to
project. 80%
Veneto goes to
project. 80%
- typer558
void
- typer558
vtec vti
ma ora l'unico che puo' sfatare questo....potresti essere tu luca....con i coll di aspirazione da pionerizzare.........quando puoi naturalmente......
I Dormienti
I Dormienti
guido51
Azz....che me so perso....sto pionierismo d'assalto , sta inventiva perenne , sta lucidita' d'intenti......
possibile che adesso me la devo menare solo con i miei pensieri....collettori...bohh...Dc-Sport , Nismo , Stillen...no meglio air intake Injen...no meglio un'altra pippa mentale....sto proprio messo alle corde , guardo l'angolo ...e' vuoto , sono scappati tutti...
