MB6 PROBLEMI ACCELERAZIONE E ACCENSIONE
LEGIONNAIRE
Re: MB6 PROBLEMI ACCELERAZIONE E ACCENSIONE
Messaggio da LEGIONNAIRE » sabato 1 dicembre 2012, 21:36
allora visto che e un lampeggio lungo il codice 10. che corrisponde IAT Sensor (Intake Air Temperature).
dove si trova questo sensore ?
ho trovato questa lista di codici errori per le honda se può essere d'aiuto.
You can jump the 2 wires on your diagnostic plug. Then read the number of flashes you get from the light. A long flash reads as a count of 10. short is a count of 1. so 3 long and 2 short would be 32. Then you can look up what code it is. That will tell you what part needs replacing.
This is the list of error codes I have for the entire Honda range. Long flashes = tens, and short flashes = single units.
1 Oxygen Sensor "A" (Primary) defective circuit or unplugged / defective sensor
2 Oxygen Sensor "B" defective circuit or unplugged / defective sensor
3 Manifold Absolute Pressure (MAP Sensor) defective circuit or unplugged /defective sensor
4 Crankshaft Angle Sensor (CAS) defective circuit or unplugged/defective sensor
5 Manifold Absolute Pressure (MAP Sensor) mechanical problem / disconnected piping
6 ECT Sensor (Engine Coolant Temperature) defective circuit or unplugged / defective sensor
7 Throttle Position Sensor (TPS) defective circuit or unplugged/defective sensor
8 TDC Position (Top Dead Centre Sensor) defective circuit or unplugged / defective sensor
9 CID Sensor (Number 1 Cylinder position) defective circuit or unplugged / defective sensor
10 IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor
11 CO pot
12 EGR Lift Sensor (Exhaust Gas Recirculation) defective circuit or unplugged / defective sensor
13 APS Sensor (Atmospheric Pressure Sensor) defective circuit or unplugged / defective sensor
14 IAC/ISCV Valve (Idle Air Control/Idle Speed Control Valve) defective circuit or unplugged / defective sensor
15 Ignition Output Signal missing or defective ignition output signal
16 Fuel Injector System defective circuit or unplugged / defective fuel injector
17 VSS (Vehicle Speed Sensor) defective circuit or unplugged / defective sensor
18 Ignition Timing
19 Automatic Transmission Lock Up Control Solenoid Valve defective circuit or unplugged / defective solenoid valve
20 Electrical Load Detector (ELD)
21 VTEC Solenoid Valve defective circuit or unplugged / defective solenoid valve
22 VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch
23 Knock Sensor (KS) defective circuit or unplugged / defective sensor
30 Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB
31 Automatic Transmission Signal "B"
41 Primary Oxygen Sensor – Heater circuit malfunction on D16Z6, D16Z7, D16A2 engines
41 Linear Air Flow (LAF Sensor) heater malfunction on D15Z1 engine
43 Fuel Supply System defective or malfunctioning fuel supply system
45 System Too Lean or Too Rich malfunction in the fuel monitoring systems
48 Linear Air Flow (LAF Sensor) defective circuit or unplugged / defective sensor
54 CKF Sensor (Crankshaft Speed Fluctuation) defective circuit or unplugged / defective sensor
58 TDC Sensor 2 (Top Dead Centre) defective circuit or unplugged/ defective sensor
61 Oxygen Sensor, Heated - Sensor 1 (Primary) high voltage, low voltage, or slow response
63 Oxygen Sensor, Heated - Sensor 2 (Secondary) high voltage, low voltage, or slow response
65 Oxygen Sensor Heater (Secondary) malfunctioning or defective oxygen sensor heater
67 Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system
70 Automatic Transmission malfunction with the automatic transmission controls
71 Cylinder 1 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
72 Cylinder 2 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
73 Cylinder 3 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
74 Cylinder 4 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
75 Cylinder 5 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
76 Cylinder 6 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input.
92 Evaporative Emission Control System insufficient purge flow
LEGIONNAIRE
Messaggio da LEGIONNAIRE » sabato 1 dicembre 2012, 22:43
trovato posizionamento sensore :sifone
Uploaded with ImageShack.us
N2O
Messaggio da N2O » domenica 2 dicembre 2012, 21:19
la mia MA8 tre anni fa ebbe gli stessi problemi cambiato spinterogeno intero e rele pompa benzina :maro
LEGIONNAIRE
Messaggio da LEGIONNAIRE » lunedì 3 dicembre 2012, 13:58
N2O ha scritto:la mia MA8 tre anni fa ebbe gli stessi problemi cambiato spinterogeno intero e relè pompa benzina :maro
grazie mille. sostituirò questi due componenti senza sbattermi più la testa per capire il difetto.
LEGIONNAIRE
Messaggio da LEGIONNAIRE » lunedì 10 dicembre 2012, 18:06
:bana problema risolto, oggi e arrivato lo spinterogeno dalla Germania, messo su e vai :sifone
problemino risolto, devo solo trovare la la messa punto migliore
mi date una dritta per fare la regolazione migliore senza andare in honda :bow
smontato il vecchio e la bobina presenta della plastica un po bruciacchiata, con calma faro la prova per vedere quale tra bobina e modulo siano andati, e cercherò con calma i pezzi per avere un spinterogeno di riserva già pronto
LEGIONNAIRE
Messaggio da LEGIONNAIRE » lunedì 24 ottobre 2016, 23:32
:( dopo 4 anni e neanche 20000 km spinterogeno andato, presso nuovo su ebay
e tutto pieno di ruggine, si e consumato il carbone perché si e ossidato e bloccato . stavo per montare il coperchio originale, non va, non corrisponde i buchi delle viti. paghi poco trovi sorprese.
MaxSbo
Messaggio da MaxSbo » lunedì 24 ottobre 2016, 23:50
Se guardi in rete trovi spinterogeni revisionati a circa 200 euro :good
Luporum
Messaggio da Luporum » martedì 25 ottobre 2016, 5:09
Cambiato modulo interno, marca Hitachi: 70€ su ebay in california.
Cambiata calotta e spazzola: 40€ dal ricambista.
LEGIONNAIRE
Messaggio da LEGIONNAIRE » mercoledì 26 ottobre 2016, 23:03
@Lupo, il modulo e a posto, il problema e il rumore, penso che e partito il cuscinetto del alberino, e pieno di ruggine al interno , la calotta non fitta perché l'interasse dei fori e diverso. dopo che lo tiro giù aggiorno. e cosi quando prendi ricambi che costano poco. mi sa che devo prenderlo alla honda che viene una fucilata.
@MaxSbo se e revisionato con dei ricambi validi va bene come prezzo, se no lascio perdere, perché non durano tanto, visto che questo era nuovo, si e rotto dopo al incirca 15000 km.
YOSHI EG9
Messaggio da YOSHI EG9 » giovedì 27 ottobre 2016, 16:37
non per fare come sempre il pignolo rompicoglioni, (tanto so di esserlo.... :goccia :angel )
maaaaa il componente di cui state discutendo,non è uno spinterogeno,bensì il distributore d'accensione :teach
Messaggio da maialedacorsa » giovedì 27 ottobre 2016, 16:40
yoshi è lo sgarbo 2.0 :asd
tommisin
Messaggio da tommisin » giovedì 27 ottobre 2016, 17:04
Però è garbato e non usa i punti, ma le virgole.
EG>ek
YOSHI EG9
Messaggio da YOSHI EG9 » giovedì 27 ottobre 2016, 20:57
:ride :ride :ride :sedia
Luporum
Messaggio da Luporum » giovedì 27 ottobre 2016, 21:22
Ho sostituito il modulo di accensione del distributore di accensione, sfruttando il trasporto aereo che ha sorvolato l'oceano atlantico e spendendo circa 135.000 lire, pari a circa 70€.
YOSHI EG9
Messaggio da YOSHI EG9 » venerdì 28 ottobre 2016, 16:38
:lol :roll :sedia
Luporum
Messaggio da Luporum » venerdì 28 ottobre 2016, 19:49
LEGIONNAIRE
Messaggio da LEGIONNAIRE » lunedì 27 febbraio 2017, 19:54
:amore dopo quasi 4 messi la bimba ha cominciato di nuovo a girare :bana
distributore d'accensione nuovo arrivato dal Giappone dopo quasi 3 settimane, e partita senza problemi, al primo colpo, rimane da regolarla per bene con la pistola stroboscopica.
pagato 655 euro in Romania concessionario honda, in Italia volevano 950 euro :rant , in Inghilterra su http://www.lingshondaparts.com veniva spedito intorno ai 760 euro dipende dal cambio. :sese che differenza da un paese al altro
avevo trovato anche questo sito http://honda-europe.epc-data.com/ . se puo essere d'aiuto per ricambi, solo che la merce arriva dal Giappone e ce la dogana da pagare.
Messaggio da manzo » lunedì 27 febbraio 2017, 20:02
ma uno di contromarca o oem usato non li hai presi in considerazione?
LEGIONNAIRE
Messaggio da LEGIONNAIRE » martedì 28 febbraio 2017, 19:35
@manzo e difficile trovarlo usato per la mb6, 3 mesi ho cercato e niente da fare, sono rimaste poche mb6 (mc2) in giro.
di contromarca non voglio più sentire, al incirca 15000 km e durato quello di contromarca presso dal ebay, tutto pieno di ruggine dentro, montato al inizio di 2013, invece quello originale sembrava quasi nuovo dopo 14 anni.
in 9 anni da quando lo presso nessun problema escluso il distributore, importante che gira adesso, e spero che gira ancora per tanti anni :amore
Luporum
Messaggio da Luporum » mercoledì 1 marzo 2017, 4:52
Ma se meccanicamente era ok, perché non sostituire solo tutti gli aggeggi elettrici all' interno?
Dentro il mio c'è la bobina e il sensore di posizione e la spazzola. Il tutto racchiuso dalla calotta...
