Vendo kit sospensione nuovo in box originale Bilstein PSS 9 (B16) per S2000 (codice prodotto W0133-1911125 ). Garantiti dalla Bilstein Germania, niente roba Cinese tipo D2 o Megan. Un bell’assetto a 360* che e’ ottimo sia in strada che in pista, con la garanzia di essere stato fatto con qualita’ e…testato sul Nurburgring!
Ecco una descrizione in inglese:
Performance Suspension System with 9 Damping adjustments, is the "race inspired" fully adjustable ride height system featuring mono-tube gas shock absorbers with nine precise damping adjustments. The system includes adjustable mono-tube gas shock absorbers with nine precise compression and rebound settings from comfort to competition, front and rear application specific, progressive rate springs allow accurate adjustment of vehicle ride height and center of gravity for the level of performance you seek.
• 9 characteristic curve pairs can be selected by adjustment wheel while installed
• Threaded body adjustable range of 20 mm at both axles while installed
• Individual settings ranging from extreme sportiness right up to the highest level of driving comfort
• Lowering of approx. 30-50 mm at front and rear
• Road-tested by BILSTEIN under motor sports conditions and fine-tuned
• Spring plates and lock nuts made from a special aluminium alloy
• Surface coating using Triple-C-Technology® for long-lasting corrosion resistance
• Round threads for perfect handling
• Quality sport springs made from highly durable material
• Gas pressure technology
• BILSTEIN mono-tube/Upside-Down technology, made in Germany
• German TÜV certificate
In pratica:
- Assetto regolabile su 9 posizioni
- Ammortizzatori a gas monotubo
- Molle progressive
- Qualita’ certificata TUV
- Serbatoio separato per i posteriori
Link
http://www.bilstein.de/products/sport-a ... n-b16.html
1850 Euro incluse spese di spedizione.
Qua un esempio di quanto costi in giro
http://cgi.ebay.it/BILSTEIN-KIT-AMM-MOL ... 483d8e0db0
[ MI ] Pss9 B16 per S2000 NUOVI
- Engo
Re: [ MI ] Pss9 B16 per S2000 NUOVI
Offro 500€ e tanta gratitudine!
- UnoTetano
li ho sempre desiderati fin da bambino
- Engo
UnoTetano ha scritto:li ho sempre desiderati fin da bambino
non sapresti nemmeno sfruttarli...
