PU Design is a brand with mainly polyurethane bodyparts in styles like JDM, SIR, Mugen, Spoon, STI, Type-R and many more.
The main difference is that the PU Design bodyparts are not made of ABS Plastic, but from Polyurethane. Painted they look the same, but it does have some major advantages.
- Polyurethaan is flexible and does not break
- Polyurethaan always have a lifetime warranty
- Polyurethaan is easy to install and always fits
- Polyurethaan is not sensitive to climate change
- Polyurethaan does not leave any permanent damage after its removed
Check this website: www.pu-design.com
Why should I choose PU Design?
When you hit a speed bump, there is a dig in the road or drive into any other obstacle your lip will no longer get damaged. As a matter of speaking you can drive into a brick wall without your PU Design part getting damaged
PU Design Products
Battle: Polyurethaan VS ABS
More information about painting Polyurethaan parts
