Verniciare il Valvecover
Messaggio da psico86 » giovedì 8 ottobre 2009, 18:56
magari è old, ma l'ho trovato su hondatech e mi sembra interessante...
So here it is, if you've ever wanted to strip the OE wrinkle heat coating from your valve cover. If this cover would have been perfect, I'd never strip it, but since it had some blemishes, decided on making my own poor man's type-r valve cover.
The Victim:
Immagine[/url]
The Murder weapon: this works much better than the spray version of the same product. KEEP this AWAY from your SKIN...if it gets on it, believe me, you'll notice. Latex gloves don't help by the way.
Immagine[/url]
The accomplice: try and stay away from nylon bristle brushes, since the stripper will eat right through it, opt for a cheap throw away "natural" bristle brush.
Immagine[/url]
Just start applying it, it doesn't need too heavy of a coat either.
Immagine[/url]
This is only after a couple of minutes, it starts to bubble. They recommend leaving it on from 15-30 minutes, but will start to work much faster.
Immagine[/url]
After a while, it will start to fall off on it's own.
Immagine[/url]
You can then use the brush to start sweeping it off.
Immagine[/url]
Immagine[/url]
No need for a crazy scrubber, the brush works fine for the OE coating....if you're trying to remove actual paint from a previous paint job, it might be more difficult.
Immagine[/url]
Also, no need for going crazy with the paint stripper, what's in the little red cup is all I used. It's the top from a can of shaving cream.
Immagine[/url]
After taking off as much as I could with the brush, I set the cover down on the floor and hosed it down with a garden hose and a little pressure.
Immagine[/url]
The results: There are still tiny bits of the heat coating, but that comes off with just a little more stripper.
Immagine[/url]
Part 2: if you've ever wanted to re-coat your valve cover with a wrinkle heat coating.
After stripping your valve cover and making sure it's clean and free of dust, you can start to cover up what you don't want sprayed.
Immagine[/url]
I use a file to file away the tape I don't want, this is how I used to remove the excess grip tape from my skateboards back in the day. I would recommend using a smaller file than I did, this was the only one I could find in my garage.
Immagine[/url]
Pretty good results
Immagine[/url]
Immagine[/url]
Immagine[/url]
Immagine[/url]
Once you've got everything covered up, it's time to start spraying.
Immagine[/url]
My weapon of choice, VHT Wrinkle Plus, this comes in either red or black and you can purchase it from Summit Racing for about $11
Immagine[/url]
I would recommend doing this on a hot day, as the heat helps the wrinkles be nice and tight.
FIRST COAT - Nice and even, don't over do it, as you'll do 3 or 4 coats in total. Obviously try not to get any drips.
Immagine[/url]
SECOND COAT - I let it set for about 10 min before I applied the second coat, again, nice even coat.
Immagine[/url]
THIRD COAT - At this point, the paint had already started to wrinkle, don't be scared, if this is the case, it's still safe to put on another coat, I found that this actually gives you a smaller wrinkle in the end, more like the OEM Honda heat coating.
Immagine[/url]
FOURTH AND FINAL COAT - This is your last coat, so make it count, make sure you cover any bare ares. **Once your valve cover dries, DO NOT re-spray it, as the wrinkles will NOT match up**Immagine[/url]
Immagine[/url]
End results - The texture came out nice and even. Keep in mind that this paint cures VERY VERY SLOWLY, as in 3 to 4 days. It dries somewhat fast, but the paint is still soft, so anything you do can alter the wrinkle, you can actually leave a big old finger print on it if you're not careful.
Immagine[/url]
Immagine[/url]
Immagine[/url]
Immagine[/url]
Part 3:
After giving the valve cover PLENTY of time to dry and cure, you can start on the last step.
Immagine[/url]
I used my Dremel with a small sanding disc for the holes around the valve cover.
Immagine[/url]
Just take your time. I wasn't too concerned with getting these super clean free of paint, since they get covered up by those...ummm whatever you call em.
Immagine[/url]
Got to work on the lower part. I put a couple layers of tape all the way around, since if you do only one and you make a mistake, the sanding cylinder will eat right through it.
Immagine[/url]
Immagine[/url]
Take it SLOW...no one needs a hero...
I got it pretty clean with the dremel, but decided to finish it off by hand with some rough sand paper. Just back and forth back and forth so you get a nice even looking "grain" to the metal.
Immagine[/url]
Immagine[/url]
Now I moved up top to the DOHC. Same process.
Immagine[/url]
Immagine[/url]
Then to the VTEC, which was what I was the most nervous about, since it wasn't as raised as the other lettering on the cover.
Immagine[/url]
DONE!
Immagine[/url]
I didn't really clean it before I put it on, but it still looks pretty nice.
Immagine[/url]
Not bad for $11 worth of paint and a little work Immagine
Immagine[/url]
fiore82
Re: Verniciare il Valvecover
Messaggio da fiore82 » giovedì 8 ottobre 2009, 21:02
psico trova quel tipo di color rosso che ne facciamo un paio
Messaggio da naisbetter » giovedì 8 ottobre 2009, 21:03
:clap
Grazie Marco
PS - mi rinvii la mail con la scansione del manualetto.... ho aperto dopo qualche giorno la posta ed è scaduto il contenuto dell'allegato.
Messaggio da denwis86 » giovedì 8 ottobre 2009, 21:07
:clap
sarebbe bello avere qualche riferimento su marchio e nome di un prodotto analogo in italia, probabilmente riuscirei a farmelo da sol pure io :alcool
rigorosamente nero però :teach
Messaggio da Sgarboman » venerdì 9 ottobre 2009, 0:38
:clap
Messaggio da NIPPONSTYLE » domenica 11 ottobre 2009, 8:37
fantastico.
Vorrei farlo anche io prima o poi...
Facciamo una cosa:
I prodotti equivalente in Italia...quali sarebbero?
Messaggio da psico86 » lunedì 12 ottobre 2009, 18:42
:ehm
non saprei..
facciamo un GB in USA
Messaggio da MOTORPUNX » lunedì 12 ottobre 2009, 19:54
Mi sembra che in Italia una vernice rossa raggrinzante la venda la D-Gear ma probabilmente sarà una merda...cmq l'avevo vista su Speed Up
ERGALmGP
Messaggio da ERGALmGP » martedì 13 ottobre 2009, 10:22
nn male..proprio ieri sera mi accingevo a sverniciare il coperchio che ho preso da sgarbo..
la vernice è ostinata..due mani di sverniciatore ma probabilmente il fatto che è stato sabbiato ha fatto da aggrappante...
io tenterò una nuova tecnica...ho preso una vernice specifica della foliatec per pinze e motori...dotata di induritore a parte..ho notato che spennellando a pressione viene grinzosa e l'effetto è molto carino...
tento la manovra durante questa settimana e vi faccio sapere
Messaggio da denwis86 » martedì 13 ottobre 2009, 10:25
Ergamede Pitagorico e i suoi esperimenti, speriamo bene :sese
ERGALmGP
Messaggio da ERGALmGP » mercoledì 14 ottobre 2009, 10:30
l'esperimento prosegue bene...la vernice è molto densa e l'effetto spazzolato rende molto.
ieri ho dato la prima mano ..lasciato ad asciugare,probabilmente ho usato poco catalizzatore e stamattina mi dava l'impressione che fosse ancora morbida.
oggi a pranzo do la seconda mano.
La cosa interessante del non verniciare a spray o col compressore è che riesci subito a coprire i punti piu nascosti e sopratutto che nn fai molto casino per verniciare.
a risultato finito posto le foto e giudicherete voi stessi....
l'effetto è molto lucido ..sembra bagnato...ora vedremo col tempo come diventerà anche se la vernice è venduta per durare.
viene venduta in kit dalla foliatec..costa una 45 di euro . contiene la vernice in barattolo,il catalizzatore e uno spray di un pulitore spray da dare prima di verniciare.
marcellomc
Messaggio da marcellomc » sabato 17 ottobre 2009, 15:28
ma a me piace il metallo vivo... controindicazioni??
ERGALmGP
Messaggio da ERGALmGP » domenica 18 ottobre 2009, 16:24
coperchio finito
Messaggio da psico86 » giovedì 22 ottobre 2009, 18:26
da vicino non sembra venuto molto bene, però oro mi piace
Messaggio da naisbetter » giovedì 22 ottobre 2009, 22:28
Ergal prova a fare una foto con luce naturale e senza flash.
Messaggio da MOTORPUNX » venerdì 23 ottobre 2009, 7:58
Il problema di non verniciare a spruzzo è l'addensamento della vernice in alcuni punti,i segni delle passate e la merda che rimane sul pennello.Infatti hai un sacco di puntini schifidi..pero' a me me piasce :bana
Messaggio da NIPPONSTYLE » venerdì 23 ottobre 2009, 8:34
psico86 ha scritto:da vicino non sembra venuto molto bene, però oro mi piace
marco...sei stato più politico del berlusca in questa affermazione!!!
:roll :roll :roll :roll :roll :roll
Messaggio da denwis86 » venerdì 23 ottobre 2009, 8:42
io ho già detto che mi fa pettare :asd fossi in te lo rifarei meglio perchè non so...non si può vedere :asd confrontato a quello rosso più su hanno un livello di finitura diametralmente opposto :sese
Messaggio da KeTaMiNa » venerdì 23 ottobre 2009, 10:57
ergal, quasi era meglio quando era in versione scroto edition :asd
ERGALmGP
Messaggio da ERGALmGP » martedì 27 ottobre 2009, 19:31
invece è bellino..nn capite niente :morte
cmq per la cronaca ne sto preparando un altro.. e mi sto facendo fare il copricoperchiocandele in carbonio..sucate!
