...::: NEW Top Secret Supra :::...
Messaggio da Acid » mercoledì 17 gennaio 2007, 0:03
guardando le foto del TAS '07, mi sn trovato sta cosa sul monitor
finchè nn ho visto il culo nn capivo che era
ah, piccola chicca
The gold one is the 5 litre V12 twin turbo with their new wide body kit. It also has an awesome fuel setup and the radiator is relocated to the rear!
The white one is the demo model for the wide body kit.
It's the engine from the Toyota Century (typical government limo), the only V12 made in Japan I think.
It's quite similar to two 1JZs on a common crank.
Ultima modifica di Acid il mercoledì 17 gennaio 2007, 0:12, modificato 1 volta in totale.
Messaggio da Acid » mercoledì 17 gennaio 2007, 0:07
aggiungo
The 1ZE-GE engine came out of a Toyota century, which is the only V12 engine made by a Japanese auto manufacturer. Smokey Nagata had this idea for a while however the engine could not be sourced until recently. The 1ZE V12 configuration is best described as that of two 2.5 liter sraight 6 cylinder 1JZ setups paired up running next to each other in harmony.
In stock forn, th V12 puts out 280ps & 49kg/m of torque.
"Although the oil pan and the engine mounts need to be fabricated, the swap seems relatively simple. I was worried about the fit but the engine fit pretty snug." claims smokey.
Further plans include twin GT turbines mounted on each side, and the target is 1000 horsepower. A Getrag 6 speed transmission with ORC triple plate clutch will be used. Just like the V35 GTR that Top Secret had mde in the past, the electronic fly by wire will be switched to a traditional cable system and 2 Fcon Vpro units will be installed.
The Supra is planned to be outfitted with Top Secret's prototype 2007 wide body kit which looks nothing like their previous GT300 series kit.
Smokey says "I've always had love for the Supras, and this V12 version is my image of the Supra of the future. I have built many Supras in the past, but this version will be the last evolution. The completion will be just in time for the Tokyo Auto Salon."
stramazzone
Messaggio da stramazzone » mercoledì 17 gennaio 2007, 0:34
SOBRIA.
void
Messaggio da void » mercoledì 17 gennaio 2007, 7:51
vorrei tanto sentire come suona
