The Acura ?MD-X Concept? luxury performance SUV made its world debut today at the 2006 New York International Auto Show featuring bold, sleek exterior styling indicative of the next generation MDX production model.
The MD-X Concept is fashioned as a true driver?s SUV, with its low, wide stance and aggressive design. Its sleek surface lines are modeled after a high-powered mega yacht.
The MD-X Concept features a wider track and longer wheelbase that give the vehicle a sportier, performance look. The profile of the concept reveals a refined SUV with smooth, chiseled lines and an elegant form. A dominant character line runs from the front quarter panel to the rear, evoking the feeling of forward movement. The sharply raked D-pillar creates a stealth, aerodynamic appearance while still retaining the third row seating functionality and cargo carrying capability of the current generation MDX.
The Concept sits low to the ground despite the large 20-inch five-spoke custom alloy wheels, while the large wheel arches and flares add to the Concept?s muscular appearance. The sleek cabin features flush mounted windshield glass, which improves aerodynamics while adding to the MD-X Concept?s smooth and flowing design.
?The smooth lines and sleek shape of the MD-X Concept challenge the conventions of SUV design,? said Ricky Hsu, chief designer for the MD-X Concept. ?Our goal was to create the image of a sports sedan while maintaining generous interior volume and utility of a SUV.?
The front hood is accented with pronounced character lines culminating in an aggressive five-sided grille, which gives the MD-X its bold presence. The commanding front grille features a dominant center bar running through a solid aluminum face. The narrow, Xenon High Intensity Discharge (HID) headlights appear to grow out of the massive grille, giving the overall front-end a strong, distinct look.
In the rear, the MD-X Concept has an integrated rear hatch, which sits flush against the bumper to create a smooth, clean appearance. LED taillights wrap around the cargo hatch adding to the vehicles wide and low appearance. A rear spoiler improves aerodynamics and the integrated dual exhaust pipes add to the SUV?s sporty style.
Production Version Coming This Fall
The next generation MDX production model will be available this fall, bringing a whole new level of performance and sophistication to the Acura light truck lineup. Track-tuned at the famed Nurburging in Germany, the all-new MDX will feature outstanding performance and handling. Equipped with a powerful, class leading V6 engine and coupled with Acura?s exclusive Super Handling All -Wheel Drive? (SH-AWD?), the next generation MDX will re-invent the luxury SUV segment just as it did when it first debuted.
2007 Acura RDX
Acura RDX Debuts At 2006 New York Auto Show. All-New Entry Premium SUV features Super Handling All-Wheel Drive & a 240 Hp 2.3 Turbocharged engine
The all-new 2007 Acura RDX Entry Premium SUV, made its production debut at the New York Auto Show today. RDX combines Acura's first-ever turbocharged engine with the breakthrough Super Handling All-Wheel Drive(TM) (SH-AWD(TM)), for sports sedan-like handling in a SUV package. Built on a new global light truck platform, the RDX concept was first designed in California and then developed in Japan. The RDX will be assembled in Marysville, Ohio, on the same line as the Acura TL sedan. It is the first Acura light truck to come from the facility.
ENGINE
As Acura's first Entry Premium SUV, the RDX was the focal point of the development of a special powertrain that would blend 4-cylinder efficiency and 6-cylinder power. The ideal solution came in the form of an innovative new variable flow turbo (VFT) that delivers an unusually broad powerband with little or no lag in throttle response. The RDX is equipped with an all-new 2.3-liter DOHC 16-valve in-line four-cylinder engine with i-VTEC valve control that combines Variable Valve Timing and Lift Electronic Control (VTEC) with Variable Timing Control (VTC). With the variable flow turbo working in concert with i-VTEC, the RDX delivers strong power and torque, excellent fuel economy and very low emissions.
Rated output for the RDX engine is 240 horsepower SAE net at 6000 rpm. In terms of torque, the RDX has the highest output of any engine in the Acura lineup, with 260 lbs.-ft. of torque SAE net at 4500 rpm. The RDX is expected to return an EPA-estimated 19/24 City/Highway mileage, while meeting strict CARB LEV-2 ULEV and EPA Tier-2 Bin-5 emissions standards.
4WD SYSTEM & TRANSMISSION
A 5-speed automatic transmission with Sequential SportShift is standard. The electronically controlled drive-by-wire throttle and transmission work together to execute shifts, resulting in exceptionally quick and smooth gear changes. The transmission can function as a conventional automatic transmission or, at the driver's option, can be shifted manually via steering-wheel-mounted paddles.
SH-AWD(TM) is standard in the RDX to maximize available traction while improving handling balance and responsiveness. SH-AWD(TM) is Acura's patented all-wheel drive system that distributes the optimum amount of torque not only between the front and rear axles but also between the left and right rear wheels.
INTERIOR
Inside the RDX, the front-seats feature a high "eye point" that provides a confident field of view. The 3-passenger rear seat has a 60/40 split-folding capability and, when folded flat, significantly expands the load area and increases the cargo volume to 60.6 cubic feet of storage. There are multiple interior storage compartments positioned throughout the interior, including a large (and lockable) dual-level center console located conveniently between the front seats that can securely accommodate a briefcase.
The RDX features an array of electronic features that set it apart from the competition. These include a dual-zone automatic climate control system, a Multi-Information Display (MID), and LED backlit gauges with progressive illumination. Also standard is an impressive 360-watt 7-speaker Acura Premium Sound System with a multi-format 6-disc changer, AM/FM tuner, XM(R) Satellite Radio, and the convenience of an MP3/auxiliary input jack for easily connecting audio devices such as an iPod.
ed io che aspetto ancora una nuova prelude o crx
