Denso Iridium IK 22 - IK 24 ( 1
AlexWoods
- Ilya
AlexWoods
- Ilya
AlexWoods
- Ilya
- typer558
Come da oggetto! Esco dal mio anonimato con il camputer del nuovo capo che è fuori per una cerimonia. Se mi becca so mazzate!
Ho trovato le risposte che cercavamo e molte altre risposte ai quesiti più strani sulle Denso Iridium. La fonte è la Denso stessa, quindi non sono opinioni personali o esperienze pioneristiche
Qui trovate il link in inglese CliccaleFaQDENSO, mentre riporto qui sotto riporto ciò che ci interessa!!
<b>Q. Do I need to set the gap?</b>
<i>A. Generally, no. The DENSO Iridium Power plug comes pre-set with a protective sleeve over the firing end, to protect the gap from accidental alteration. DENSO Iridium Power?s ultra-efficient firing power compensates for normally recommended gap settings that are smaller than the pre-set value. In the cases of vehicle modifications (nitrous, turbo-chargers, super-chargers, high power ignition systems, etc.), some adjustments may be desired. Or, if you prefer to remain consistent with factory specifications, you may adjust. However, please be careful not to place any stress on the fine center electrode during adjustment. You could accidentally break off the very hard, and therefore brittle, tip.</i>
- gizmoITR
- typer558
<b>Q. How do I gap Iridium plugs</b>
<i>A. Before attempting to gap any DENSO Iridium Power spark plug, please review the specification chart to see the factory-preset gap. In most cases your Iridium Power plugs do not need to be gapped. <b>Even with small variations in the factory set gap the ultra-efficient firing power design will compensate for those small variations.</b> Should you decide to re-gap your Iridium Power plug, use extreme caution as improper gapping may damage or destroy the Iridium center electrode or porcelain center. To increase the gap size: Step 1 Use needle nose pliers or spark plug gapping tool to bend the ground strap up to the desired height. DO NOT LET THE PLIERS OR GAPPING TOOL TOUCH THE IRIDIUM CENTER ELECTRODE OR PORCELAIN. Step 2 Re-check the gap with a calibrated gapping tool. To decrease the gap size: Step 1 Use the same method as above, however bend the ground strap down to the desired height. DO NOT LET THE PLIERS OR GAPPING TOOL TOUCH THE IRIDIUM CENTER ELECTRODE OR PORCELAIN. Step 2 Re-check the gap with a calibrated gapping tool. WARNING: Failure to follow these directions may permanently damage the spark plug. Note: Never use a round gapping tool to check the gap or to increase or decrease the gap setting</i>
AlexWoods
- typer558
non penso che qualcuno le abbia ordinate mai.
Che codice hanno quelle spoon?? 22 o 24??
Ora le ordino e tagliamo la testa al toro!
Appena mi arrivano, stesso qui riposto il gap misurato!
A presto!!
ps
l'orologio segna le 07.48.........sta arrivando il Capo........vado a nascondermi!!!!!!!!!!!
A presto!!
ps
- AieieVTEC
Che io sappia Soul le comprò in un ordine di Taka e comunque sono le IK24...
_____________________
Per INFO: gurumbun@tiscali.it<i>Edited by: AieieVTEC at: 12/5/04 10:49
</i>
</i>
- Looka
Le avevo, non le ho montate e non ho nemmeno gli strumenti per controllare il gap me spias
looka79@libero.it
looka79@libero.it
GIMME A HELL, GIMME A YEAH!
AlexWoods
soul of darkness typeR
IO ho comprato le spn e il gap è a 0.8 .e secondo me su quelle candele non va toccato ,altro che 1.1 quello vale sulle candele tradizionali
T?tti se dixe che l'è m?gio st?sene fantin,
che sotta donne e figgi?u en castigo de Dio.
Ma l'è anche v?a che un pei de mussa o t?a de ciù
che 'na cubia de b?u.<i></i>
- typer558
- typer558
Stavo vedendo sul sito densoiridium.com (nella scheda tecnica) che le caratteristiche delle IK 24/22 sono:
gap a 0.8 e il gap (in) settato a 0.032.
Se invece faccio una ricerca (sempre su quel sito) del tipo di candela da montare sul mio K20A2 (la CTR non c'è, bisogna inserire la ACURA RSX-S anno 2002), il risultato è sempre IK 22 (24 se le volete più fredde), ma nella sceda tecnica mi si dice che il gap (in) deve corrispondere a 0.044, indi ne deduco che su quel tipo di motore, la IK deve essere settata a 1.1 anche se esce con il gap originale a 0.8.
Provate e vedrete che tutte le honda le da con il gap-in a 0.044, anche se la IK esce con il gap-in a 0.032.
Onestamente, non ci capisco più un caxxo Aspetto di avere le Spoon per misurare il gap. Adotterò quello, mi sembra l'unica soluzione
Celima
le candele che arrivano dalla Spoon sono delle normalissime Denso e precisamente IK24
Il gap è di 0,8
E quando le compri non dici per che Honda.....ti mandano solo quelle li...punto
Sulla mia sono settate a 1,0 (modificate da me)....ora me ne arrivano 4 nuove...e provo a lasciarle come Denso me le manda
Il gap è di 0,8
