Messaggio
da poSEIdon » martedì 5 gennaio 2010, 13:59
da wiki:
B18C6
VTEC
Found in:
1998-2001 Honda Integra UK and Euro Spec Type R
Type: 1.8 litre 16v DOHC 4 cylinder in-line
Displacement: 1,797 cc (109.7 cu in)
Compression: 11.1:1
Air intake diameter: 62 mm (2.4 in)
Bore: 81 mm (3.189 in)
Stroke: 87.2 mm (3.433 in)
Rod Length: 137.9 mm (5.429 in)
Rod/Stroke Ratio: 1.58
Power: 190 PS/140 kW @ 7900 rpm & 131 ft·lbf/178 N·m @ 7300 rpm
Redline: 8400 rpm
Rev-limiter: 8700 rpm
VTEC engagement: 5700 rpm
Transmission: S80 w/LSD
