Tought it would be nice to show our Time Attack car
Car model: Honda civic coupe
Engine: B18C JDM
Suspension: JDM DC2 4x114.3
Tranny
-b16a2 tranny
-s80 LSD
-Exedy stage 3 clutch
-b18c flywheel
-Stainless steel braided clutch hose
Engine
-B18c JDM
-Overhauld head
-Milled head
-OMI-performance high compression valves
-OMI-performance valve springs
-OMI-performance titanium retainers
-OMI-performance camgears
-Stock cams (will be Toda C in the future
-OMI-performance prototype pistons 11.40:1 CR
-Bored and honed
-Blueprinted crankshaft
-Blueprinted flywheel
-Blueprinted pulley
-ARP rodbolts
-ARP main studs
-ARP headbolts
-ARP flywheel bolts
-ARP clutch bolts
-BLOX intake (will be 52mm Throttlebodies soon)
-68MM ALU Throttlebody (will be removed soon)
-Showoffimports.nl Cold air intake (will be replaced by a airbox
-SRS 4-1 header
-Custom made exhaust with 2 dempers
Engine bay and fueling
-STR engine mouts
-ATL fuelcell 40 Ltr
-Bosch external fuelpump
-FIA approved fuel lines
-FIA approved couplers
-FIA approved fuel filter
-Showoffimports.nl fuel rail
-QSP fuel pressure gauge
-Showoffimports.nl aluminum radiator
-Custom wiper fluid reservoir
-DC2 steering rack
-Power steering removed
Suspension
-Biesheuvel KNAF approved rollcage
-OMI-performance SPEC SR suspension 14k front, 10k rear
-D2 toe kit rear
-D2 camber kit rear
-Buddyclub camber kit front
-Energy suspension bushings
-Ultra racing front strut bar
-Megan racing H-brace
-DC2 Integra 4x114,3 suspension
-Rota circuit 8 with toyo r888 tires
-ASR brace rear
-JDM front DC2 swaybar
-JDM rear DC2 swaybar
Brakes
-D2 Big brake kit 286 front 6 pod
-Stainless steel braided brake hoses
-Wilwood brake balance controler
-Stock rear brakes with ferodo ds2500 pads
-1 inch MBC
Exterior
-Carbon fiber hood invader style
-Buddyclub 1 bodykit
-Custom rear diffuser
-Eagle diffuser
-Lexan side windows
-Custom brake ducts
