I love it.
Why dou use a small radiator?
OMI-performance Tima Attack race car!
- luchjeg6
OMI-performance
Re: OMI-performance Tima Attack race car!
Thanks all
The reason we use a small radiator is that it is more the sufficient. We will later make a 'air dam' that will force the air straight trough the Aluminum radiator.
Also Updates
As you can see we are building up the engine. When we took the engine appart, we've noticed that the wall of the 3rd cilinder was not 100% Ok. there were grooves al over the cilinderwall. We decided to bore the engine by .50 oversize and use our prototype pistons.
The pistons are casted and will be made to fit a floating pin connecting rod. This piston is just a sample to see it the piston can handle some abuse on the track.
We are also making a triggerwheel for the Emerland stand alone system that will be fitted later this week!!
More updates will follow shortly
Also Updates
