Presentazione [ + consigli.. mini+b16]
ignoto83
Re: Presentazione [ + consigli.. mini+b16]
Messaggio da ignoto83 » martedì 16 settembre 2008, 16:08
bagga typeR ha scritto:per i consigli aspetta i più esperti... :teach
intanto ti faccio un in bocca al lupo per il progetto...complimenti... :clap
:bana :bana :bana :bana
Fn2
Ex Civic EK4
Ex Honda Civic EP2 Sport
Ex Honda Prelude 5° gen
type aru
Messaggio da type aru » martedì 16 settembre 2008, 18:56
:welcome
Gran progetto ti faccio i miei auguri..
Ma questa mini di che anno è? versione?
una rapida occhiata da wikipedia intanto cosi valuti i diversi B series
B16A
Note: All JDM B16A engines are stamped 'B16A' (with no number after the "A" to identify version).
VTEC
Found in:
1988-1991 JDM Honda Integra RSi/XSi (DA6/DA8)
1988-1991 JDM Honda CRX SiR (EF8)
1988-1991 JDM Honda Civic SiR (EF9)
Displacement: 1595 cc
Compression: 10.2:1
Rod/stroke ratio: 1.74
Power: 158 hp (118 kW) @ 7600 rpm & 111 ft·lbf (150 N·m) @ 7000 rpm
Transmission: S1/J1/Y1/YS1
1992-1996 JDM Honda CR-X del Sol SiR (EG2)
1992-2000 JDM Honda Civic SiRII (EG6/EG9/EK4)
Compression: 10.4:1
Power: 170 hp (130 kW) @ 7800 rpm & 116 ft·lbf (157 N·m) @ 7300 rpm
Transmission: S4C/Y21 (Some with LSD)
Redline: 8200 rpm
[edit] B16A1
VTEC
Found in:
1990-1991 EDM Honda CRX 1.6i-VT (EE8)
1990-1991 EDM Honda Civic 1.6i-VT (EE9)
Bore×Stroke: 81.0×77.4 mm / 3.19×3.05 in
Compression: 10.2:1
Power: 150 hp (110 kW) @ 7600 rpm
Torque: 109 ft·lbf (148 N·m) @ 7000 rpm
Redline: 8200 rpm
Transmission: y7
[edit] B16A2
VTEC
Found in:
1992-2000 Honda Civic EDM VTi (EG6/EG9 & EK4)
1992-1997 Honda Civic del Sol EDM VTi (EG)
1999-2000 Honda Civic USDM Si (EM1)
Bore x stroke: 81mm x 77.4mm
Compression: 10.4:1
Power: 158 hp (118 kW) @ 7800 rpm & 113 ft·lbf (151 N·m) @ 7000 rpm
Transmission: Y21
[edit] B16A3
VTEC
Found in:
1994-1995 Del Sol VTEC
Displacement 1595 cc
Transmission: Y21
[edit] B16A4
VTEC
Found in:
1996-2000 Honda Civic SiRII (Asian version) (EK4)
Compression: 10.4:1
Power: 170 hp (127 kW) @ 7800 rpm & 116 ft·lbf (157 N·m) @ 7300 rpm
Transmission: Y21
[edit] B16A6
VTEC
Found in:
1996-2000 Honda Civic - Middle East & South Africa VTEC (EK)
Compression: 10.2:1
Power: 158 hp (118 kW) @ 7600 rpm & 111 ft·lbf (151 N·m) @ 7000 rpm
Transmission: S4C
[edit] B16B (Type R)
VTEC
Found in:
1997-2000 Civic Type R[EK9]
Compression: 10.8:1
Bore: 81 mm
Stroke: 77.4 mm
Rod/Stroke ratio: 1.84:1
Rod Length: 142.42 mm (5.607")
Power: 170 hp (134 kW) @ 8200 rpm & 115 ft·lbf (155 Nm) @ 7500 rpm
Redline: 9200 rpm
Transmission: S4C With LSD
VTEC engagement @ 6,000 rpm
Note: This engine uses the same block as the Integra Type R, which is taller than the B16a block, but with a crank the same stroke as the b16a. It uses longer rods to accommodate for this, which is why the Rod/Stroke ratio is higher than a standard B16.
Messaggio da bagga typeR » martedì 16 settembre 2008, 19:14
b16b... :amore :amore
ignoto83
Messaggio da ignoto83 » martedì 16 settembre 2008, 21:42
si ma si parla di pagà poko... indi penso che i piu facili da trovare sono il b16a1 e b16a2.... che io sappia... il b16a1 (eg6) è un po piu arrogante, ma andrei di b16a2 (ek4) dato che è piu recente! e poi.... ek4>eg6 :asd
Fn2
Ex Civic EK4
Messaggio da manzo » martedì 16 settembre 2008, 21:50
eg6 b16a2 ;)
ignoto83
Messaggio da ignoto83 » martedì 16 settembre 2008, 22:33
fermitutti! volete dirmi che sono anni....... :azz
ero convinto che eg6 avesse sto b16a1 :stica
Fn2
Ex Civic EK4
Pantuz
Messaggio da Pantuz » mercoledì 17 settembre 2008, 9:33
EG6=B16A2 (che sceondo me è quello su cui devi puntare perchè è di più facile reperibilità)
Se cerchi in rete, trovi un'azienda che vende un kit per la supportazione motore e resto. Però non mi ricordo come si chiama...
Honda Civic VTi EG6
Honda Integra Type-R n°1411
drake83
Messaggio da drake83 » mercoledì 17 settembre 2008, 13:14
Pantuz ha scritto:EG6=B16A2 (che sceondo me è quello su cui devi puntare perchè è di più facile reperibilità)
grassie!!!! il sito che dici tu lo già spulciato tutto.. ma nn voglio prendere un kit ultra completo... uno per il prezzo e due perchè sennò che gusto c'è????
per il motore seguirò il tuo consiglio... eeee anche se presto io la butto li.... qui sul forum si recupera?
comunque man mano che andrà avanti il progetto... diventerò più scassatore!!! :sifone
l'anno della mini in realtà nn lo so ma è sicuramente prima del 73... perchè oltre alla questione auto d'epoca.. sul libretto aveva solo i dati essenziali senza misura delle gomme ecc... :asd
ignoto83
Messaggio da ignoto83 » mercoledì 17 settembre 2008, 14:30
urca..... possibile?!?! :eh
Fn2
Ex Civic EK4
drake83
Messaggio da drake83 » mercoledì 17 settembre 2008, 14:47
:roll si si :roll
RobyVTEC
Messaggio da RobyVTEC » mercoledì 17 settembre 2008, 23:30
Benvenuto ;)
specRR Dark Lady
marco ee8
Messaggio da marco ee8 » venerdì 19 settembre 2008, 10:57
:welcome
Luporum
Messaggio da Luporum » sabato 20 settembre 2008, 10:22
drake83 ha scritto:
il progettino è solo all'inizio infatti diciamo che per ora abbiamo una mini.. che in realtà nn è quella in foto ma era per rendere l'idea... :sifone che nn vi dico com'è messa.. moolto male ma l'abbiamo cercata apposta così.. abbiamo il posto e un superesperto di mini che ci supporterà nella sua officina!!
:sigh
Sono felice per il vostro progetto, anche se mi spiace quando si "tocca" una mini...
Ho due mini, una cooper del 72 ed una minor del 68, sarei felice di "conoscere" il vostro esperto per poter aumentare un pò le mie.
Buon lavoro. :good
DiegoVTEC
Messaggio da DiegoVTEC » sabato 20 settembre 2008, 11:28
lupo xchè qst discriminazione? anche qll "mini" vanno toccate....gli piace lo stesso :amore :amore :amore
cmq sia :welcome
Luporum
Messaggio da Luporum » sabato 20 settembre 2008, 11:43
drake83
Messaggio da drake83 » sabato 20 settembre 2008, 12:08
Luporum ha scritto: Sono felice per il vostro progetto, anche se mi spiace quando si "tocca" una mini...
Buon lavoro. :good
grazie per i link.. li avevo già ma grazie mille comunque!!
per il discorso delle tue mini.. se vuoi ti ci porto volentieri da lui ha un'officina a rosate, esteticamente poco curata ma immagina un bel capannone sommerso e dico sommerso seriamente di mini!!!!
Se devi farci mettere le mani lui è il migliore... un 100.. 105 cv da 1.3 nn li vorresti??? :sifone
Luporum
Messaggio da Luporum » sabato 20 settembre 2008, 12:40
Buon lavoro. :good
A me basta sapere che c'è qualcuno che può metterci le mani sopra. Il minor è stato rifatto tutto ma è fermo da un pò di tempo. Il cooper pure ma più di recente.
Appena monto le porte al garage nuovo le porto a casa mia, intanto un giretto dal tuo amico non mi dispiacerebbe.
Tra l'altro Rosate non è lontano da me (Pavia) e quindi sarei anche comodo.
drake83
Messaggio da drake83 » sabato 20 settembre 2008, 19:22
nn c'è problema.... tanto sai come trovarmi... e poi quando inizieremo a lavorarci seriamente credo che nn ci sia nessun problema se qualcuno vuole venire a trovarci!! :good
Bbirra
Messaggio da Bbirra » martedì 23 settembre 2008, 14:14
:welcome
terry-fc
Messaggio da terry-fc » mercoledì 24 settembre 2008, 17:24
:welcome
