The kit is an aluminium airbox with heat resistant material, carbon intake pipe and carbon cold feed,
The filter is F1 spec foam, with the highest flow capacity, with a CNC machined aluminium bell mouth and carbon veins.
The kit also uses a Power check gauge, this mesures the restriction of the intake kit and lets you know when the filter needs replacing...See below.
