There are two main types of brake fluids:
* DOT 3, DOT 4, Super DOT4* and DOT 5.1 which are based on poly glycol compounds.
* DOT 5, which are based on Silicone.
Note the two types of fluid are not compatible and must not be mixed in a braking system.
SILICONE BRAKE FLUID (DOT 5)
Silicone based DOT 5 was originally introduced to give higher temperature performance over glycol DOT 4. Silicone fluid also has other advantages, it does not damage paintwork and it does not absorb water.
However, silicone fluid is a poor lubricant and does not lubricate ABS pumps as well as PAG fluids. It is also more compressible than PAG fluids, which can result in a sluggish or spongy pedal. It therefore requires special design considerations in braking systems. Further, because it does not absorb water, any water remains as globules, which can pool in low spots in the system and cause corrosion. This water can vaporise when heated under heavy braking giving a disastrous effect on braking efficiency.
DOT5 fluids are not recommended for motor sport applications.
Re: [WIP] EG6 white
- Ghost
Re: [WIP] EG6 white
Michel_ITR99 ha scritto:There are two main types of brake fluids:
" ...senza il disappunto del vinto...non si apprezza la vittoria! " (Driftlord)
- tonyclifton
Re: [WIP] EG6 white
I colli fanno un po' tenerezza, sono piccoli piccoli!!!
Ma sicuramente son meglio degli stock, pesano la metà e magari non c'è nemmeno tutta sta differenza da altri più seri!!
Comunque per i freni ricorda che puoi mettere i dischi MG ZR160 senza distanziale anche con le pinze ITR!!
マキシム
マキシム
- unreal
Re: [WIP] EG6 white
effettivamente sti ss sembrano molto stretti nella parte iniziale..
hondista,hondiere,hondaio!!!
- Ghost
Re: [WIP] EG6 white
L'uscita finale dei colli pero è da 51mm interni....il mio centrale è da 51mm interni quindi dovrebbe risultar un buon accostamento...in più non sporgendo sotto non strusciano facilmente!
Cmq provandola ho notato molta piu spinta in basso e un allungo sensibilmente migliorato.....non so dire quanto gli abbiano fatto...ma un po si...e si sente,dopo averli montati mi hanno consigliato di effettuare il reset della centralina e lo ho fatto...non so cn quali risultati perche la sera stessa che li ho montati son venuto a casa e ho staccato la batteria per l intera notte....
tra un po compro la puleggia servizi tegiwa che montero assieme al volano da 6,3kg e alla frizione,e insieme al corpo farfallato ITR....coglierò l occasione per cambiare anche olio al cambio!
- tonyclifton
Re: [WIP] EG6 white
Ma scusa ma vale la pena montare un volano che pesa solo un kg e spicci in meno?? Nemmeno si sente....
マキシム
マキシム
- Ghost
Re: [WIP] EG6 white
tonyclifton ha scritto:Ma scusa ma vale la pena montare un volano che pesa solo un kg e spicci in meno?? Nemmeno si sente....
1,5kg in meno di massa sul volano credo si sentano.....ho parlato con un ragazzo (conosciuto cm uno sufficientemente competente) del forum che mi ha detto che montandolo avrò solo benefici....poi sinceramente per averlo preso a 50 euro....mi accontento,ovviamente un volano da 4 kg sarebbe stato piu consono ma credo che forse avrei perso troppo in salita e vel.max....
- tonyclifton
Re: [WIP] EG6 white
Mah, vedrai che non sentirai nessuna differenza!Ghost ha scritto:tonyclifton ha scritto:Ma scusa ma vale la pena montare un volano che pesa solo un kg e spicci in meno?? Nemmeno si sente....
1,5kg in meno di massa sul volano credo si sentano.....ho parlato con un ragazzo del forum che mi ha detto che montandolo avrò solo benefici....poi sinceramente per averlo preso a 50 euro....mi accontento,ovviamente un volano da 4 kg sarebbe stato piu consono ma credo che forse avrei perso troppo in salita e vel.max....
Io con quello da 4,4 non ho perso ne ripresa ne velocità di punta............
マキシム
マキシム
- Ghost
Re: [WIP] EG6 white
quindi sostieni sia completamente inutile montarlo?
- tonyclifton
Re: [WIP] EG6 white
Secondo me con così poca differenza assolutamente si!!Ghost ha scritto:quindi sostieni sia completamente inutile montarlo?
マキシム
マキシム
- Ghost
Re: [WIP] EG6 white
ok,ora ce l ho lo monterò e quindi lo proverò se cosi fosse...mi metterò alla ricerca di un volano più leggero...
io non sono molto convinto!e spero,abbinandolo al corpo farfallato e alla puleggia servizi,di sentire qualche beneficio....
grazie cmq del consiglio!
- tonyclifton
Re: [WIP] EG6 white
E' ovvio che se già devi cambiare la frizione ti conviene metterlo che ma le non farà.... Tutt'al più se è uno stock alleggerito verifica che sia perfettamente equilibrato!!
マキシム
マキシム
- Ghost
Re: [WIP] EG6 white
tony per vedere se è equilibrato il tizio della rettifica mi ha detto che dovremmo metterlo sul macchinario con un albero motore...io nn ho un albero motore a portata di mano.....ma siccome mi stai facendo venire seri dubbi e profonde avversioni verso codesto oggetto....
mi sa tanto che me ne compro uno apposito piu leggero di questo....
nn vorrei far danni al mio motore!
in media che prezzi hanno i volani alleggeriti? ce ne sono da 5kg?o passo direttamente ad uno da 4,4kg?
- tonyclifton
Re: [WIP] EG6 white
Guarda, io al contrario di quello che mi disse qualcuno non ho riscontrato nessuna seccatura col volano da 4,4....Ghost ha scritto:tony per vedere se è equilibrato il tizio della rettifica mi ha detto che dovremmo metterlo sul macchinario con un albero motore...io nn ho un albero motore a portata di mano.....ma siccome mi stai facendo venire seri dubbi e profonde avversioni verso codesto oggetto....
La differenza è avvertibile ma un possessore di EK stock non so se guidando la mia se ne accorgerebbe....
Figurati se togli solo 1,5kg... Io pagai il mio usato un centinaio, magari se chiedi ne salta fuori qualcuno!
マキシム
マキシム
- HillsKiller
Re: [WIP] EG6 white
il mio è molto leggero, un act... salgono parecchio veloci i giri...
e riesco a fare ancora i 12 in città nonostante quello che ho tutto montato...
MUGEN無限POWER
ホンダ シビック Eg6 owner
УАЗ 469 owner
インプレッサWRX owner
ホンダ シビック Eg6 owner
УАЗ 469 owner
インプレッサWRX owner
- Filo83
Re: [WIP] EG6 white
io anche ho un ACT, sale molto piu' rapidamente, e non si ammoscia nei cambi marciaHillsKiller ha scritto:il mio è molto leggero, un act... salgono parecchio veloci i giri...![]()
certo ha il suo prezzo...
- Ghost
Re: [WIP] EG6 white
che prezzo ha?
avete qualke link di volani per b16a2 da passarmi ?
Re: [WIP] EG6 white
http://www.risingsunperformance.nl/act- ... s-all.html
- Ghost
- tonyclifton
Re: [WIP] EG6 white
Io però prenderei uno tutto acciaio.... Su ibei se ne trovano a decine!!
マキシム
マキシム
