buon viaggio
F430 in 3d
- luchetto
- Yankee
- TIA
Re: F430 in 3d
ma dove sono i tasti alza-cristalli?
- Toro-R
Re: F430 in 3d
A me sembra la scuderia
Ma io sono solo uno sborone
:keta
- Janjo
Re: F430 in 3d
Ai lati dell'ipod incassato nel cruscotto al centro... sono quelli col disegnino in giallo...
Si,è la scuderia spyder in serie limitata per la storia dei 16 mondiali costruttori,se non sbaglio si chiama 16M appunto...
- Rally
- luchetto
Re: F430 in 3d
Janjo ha scritto: Si,è la scuderia spyder in serie limitata per la storia dei 16 mondiali costruttori,se non sbaglio si chiama 16M appunto...
SCUDERIA SPIDER 16M - TECHNICAL SPECIFICATIONS
Engine
Naturally aspirated mid-rear 90° V8, 4308 cc
Maximum power output 375.4 kW (510 hp) at 8500 rpm
Maximum torque 470 Nm (47.7 Kgm) at 5250 rpm
Max engine speed 8640 rpm (at limiter)
Compression ratio 11.9:1
Bore and Stroke 92 mm X 81 mm
Specific power output 118.4 hp/litre
Transmission
Six-speed plus Reverse F1 gearbox
Dry dual clutch
Electronic differential E-diff + F1-Trac
Oil gearbox lubrication with oil/water heat exchanger
Performance, fuel consumption, emissions
Acceleration 0-100 km/h 3.7 s
Maximum speed 315 kph
Drive weight/power 2.6 kg/hp
Fuel consumption 15.7 l/100 km (combined ECE)
CO2 emissions 360 g/km (combined ECE)
Chassis and bodywork
Car dimensions:
- Length 4512 mm
- Width 1923 mm
- Height 1216 mm
- Wheelbase 2600 mm
- Front track 1669 mm
- Rear track 1616 mm
Dry weight * 1340 kg (-80 kg vs F430 Spider)
Kerb weight * 1440 kg
Weight distribution 43% front, 57% rear
Fuel tank capacity 95 litres
Independent front and rear forged aluminium double wishbone suspensions, titanium helical springs, hollow anti-roll bars and lighter electronic shocks
398mm X 36mm carbon-ceramic material front brake discs with aluminium 6-pot callipers
350mm X 34mm carbon-ceramic material rear disc brakes with aluminium 6-pot callipers
19" five-spoke split rims front and rear
Tyres: 235/35 front and 285/35 rear; Fabbrica Pirelli PZero Corsa only
- Mugen_Stumpo
Re: F430 in 3d
belli i tappetini di mandorlato... come i tamarroni
- Filo83
Re: F430 in 3d
carbonio e alcantara, il mio sogno
interessanti i contenuti dell'iPod Touch
valvolin
Re: F430 in 3d
io mi chiedo solo a come sia possibile omologarla.
Al primo incidente l'autista muore d'infezioni da scheggie di carbonio
Boh.
Boh.
- denwis86
Re: F430 in 3d
118,6cv/l Fuckin' ferrari... :loser
S2000 VIIIIIIIIIIIIITEEEEEEEEECCCCKKKKK! yeah!
- AliEN61
Re: F430 in 3d
quanto carbonchio, dentro è stupenda
.... fuori
- Toro-R
Re: F430 in 3d
Alex, senza offesaalex_novi ha scritto:118,6cv/l Fuckin' ferrari... :loser
Ma baffanculoooooooooooooooooooo
:keta
Re: F430 in 3d
100cv/l :BAH
per favore risparmiami a monza!
- denwis86
Re: F430 in 3d
i primi sintomi di lolhonditealex_novi ha scritto:118,6cv/l Fuckin' ferrari... :loser
Fuckin' Ferrariiiiiiii
geidiem!
ma in caso di incidente tutto quel carbonio interno?
ripetendo la domanda di qualcun altro...
- luchetto
Re: F430 in 3d
QuotoneToro-R ha scritto:Alex, senza offesaalex_novi ha scritto:118,6cv/l Fuckin' ferrari... :loser
Ma baffanculoooooooooooooooooooo![]()
Re: F430 in 3d
Ferrari is not GEEEEEIIIIIDIIIIIIIIIIIIIIIEEMMMMMMMMMMMM
- luchetto
Re: F430 in 3d
Infatti io amo le auto sportive,nn quelle etichettate.La S avrà anche 120CV/lt ma ormai è vecchia,e molte altre auto con meno CV e + leggere le fanno male,quindi nn è il top in assoluto,un po di razionalità nelle cose....nn abbiate i paraocchi
- NIPPONSTYLE
