Io le vedevo ma perché le avevo nelle cache.
Sono nel mercatino del club lancer
http://www.vividracing.com/catalog/sear ... r+evo.html
http://monster-sport.com/e/car/evo8.html
Rear spats della Monster . Somigliano molto a quelli della S.
Farli nero opaco e rivettarli alle minigonne ?
EDIT
Hanno anche lo spessore per rialzare l'ala alta tipo quello che monta la Celica GT4...
http://www.monsterunit.net/vineytme.html
Car: 2000 Mitsubishi Lancer Evo VI Tommi Makinen Edition [CP9A]
Photo Credit: Gary Boyd
Engine: - 2.0L Forged 4G63 DOHC 16 Valve Engine - Wiseco Pistons - Brian Crower Conrods - ACL RACE Bearings - ARP Head Bolts - Balanced EVO8 Crank Shaft - MR Head Gasket - All New Oem Seals, Water Pump And Oil Pump - All New Rebuilt Ported And Polished Cylinderhead - Up Rated 3mm Lash Adjusters - NGK Iridium Spark Plugs - Brian Crower 272 Camshafts - Piper Adjustable Cam Pulleys - CR 2.0bar Hybrid Turbo - Greddy Intercooler - Greddy Alloy Intercooler Piping - Alloy Intake Pipe With Tial 50mm Blow Off Valve - Custom 4" Induction Pipe - 4" Turbo Shroud - HKS Reloaded Mushroom Filter - MAF Deleted - SAS Deleted - Blitz Nurspec-R Cat Back, Restriction Removed (True 3") - 3" Magnex De-Cat Pipe - 3" Magnex Downpipe - Uprated Turbo Elbow - Engine Management - Autronic ECU With Anti-Lag & L/C - Autronic Air Temp Sensor - Walbro 255 Intank Fuel Pump - RC 1000cc Injectors - Sard Fuel Pressure Regulator - Greddy Profec-II Boost Controller Display - Greddy Turbo Timer - LTS Clear Cam Cover - Monstersport Carbon Plug Cover - Custom Painted Rocker Cover & SS Bolts - HKS Earth Circle & Cables - Roundsport Race Battery With Alloy Holder & Ralliart Clamp - Custom Battery Poles With Gold Plated Connectors - Spec-R Alloy Oil Catch Tank / PX Small Filter - Spec-R Alloy Header Tank - Spec-R Alloy P/S Tank - Spec-R Alloy Alloy Fuse/Relay Box Covers - ARC Shinny Exhaust Manifold Heat-Shield - HKS Up-Rated Oil & Water Caps - Koyo Alloy Radiator - Samco Hosing All Round, Water, Heater, Couples Etc - Pacet 12" Slimline Radiator Fan - Powerflex Engine Mount Bushes - Carbon Goodies Carbon Fibre Slam Panel - Roundsport Alloy Rad Brackets - Scott-Lowe Carbon Fibre Gas Bonnet Struts - Neverneverman Bonnet Tilt And Cam Sensor Shield
Transmission: - ACT Organic With Heavy Duty Pressure Plate - ACT Lightweight Flywheel - Powerflex Gearbox Mount Bushes - Powerflex Diff Mount Bushes - Neverneverman Solid Gear Bush Mounts And Link
Interior: - Bride Gias [Kevler/Graduation] - Bride RO Rails - Takata Harness And Pads - Keys Racing Steering Wheel - HKB Boss - Greddy Profec-II Boost Controller Display Mounted In Ash Tray - Greddy Turbo Timer Mounted In Ash Tray - Bride Floor Mats - A/L Switch - Custom Mounted Launch Control Button
Exterior: - Cartel Custom Lip - Carbon Fibre Skirts And Spats - Scott-Lowe Carbon Fibre Mud Flaps - Rallytech Carbon Fibre Wing Mirrors - Rallytech Carbon Fibre Rear Window Vents - Carbon Goodies Carbon Fibre Naca Ducts - Carbon Goodies Carbon Fibre Exhaust Surround - Clear Front Indicator Lenses With Silver-Tec Bulbs - Clear Side Repeaters - Okuyama Tow Hook - Oem Wind Deflectors
Chassis: - Tein Monoflex Coilovers - Tein Adjustable Pillowball Top Mounts - EDFC Controller - Carbing Front Upper Strut Brace - Carbing Rear Upper Strut Brace - Powerflex Bushes All Round - Whiteline Front Anti-Roll Bar & Bushes - Whiteline Rear Anti-Roll Bar & Bushes - Whiteline Front & Rear Adjustable Droplinks - Whiteline Bump Steer Kit - Geometry Set-Up By Kenneth Brown Engineering
Wheels & Brakes: - Rays Volk CE28N 18x8.5 [Now Gloss Black] Lightweight Wheels - Volk Racing Centre Caps - Rays Lightweight Wheel Nuts - ADVAN A048 - AP Racing 6-Pot (CP555) Front Calipers & 362mm Discs, With DS2500 Pads. - AP Racing 4-Pot Rear Calipers & Matching Grooved 310mm Rear Discs With DS2500 Pads. - Front & Rear Goodridge Hose's & Castrol SRF Brake Fluid.
