DTM 2012
DTM 2012
Messaggio da Acid » giovedì 15 marzo 2012, 17:02
Visto che non ci parla mai nessuno, inizio io :asd
full res link: Qui e Qui
Pick one of three DTM cars you see here at random - the Merc C-Class coupe, for example - and you'll find it has 25 wings. Twenty- five. Roll that figure around in your mind for a minute, and compare it to other bewinged inventions - a 747, for instance. That's only - technically - got five. British Touring cars, the UK equivalent of Germany's DTM, have just one. If there were a world championship for wings, the DTM would sew up the podium every time.
But every single flick and flap has a purpose. This year more than ever, because the DTM - Deutsche Tourenwagen-Meisterschaft, to give it its full title - will be contested for the first time by the cars you see here. The German Big Three. Mercedes vs Audi vs BMW. The three biggest rivals in car manufacturing will all be hammering the same bit of tarmac with full works backing. Three makers that strive every day to launch a road car that bests the others.
The 2012 regs have changed to keep costs some 40 per cent lower. So DTM organisers standardised over 50 parts - stuff like the carbon chassis, the Hewland paddle-shift gearbox, the dampers and the steering rack - which means that all three manufacturers will effectively just pick these bits up off the shelf. It also means new-boy BMW shouldn't be too far behind championship stalwarts Audi and Merc, because it won't have to spend as long developing the complicated bits. Mind you, the engine is still unique, and that won't be an easy job.
Aerodynamics is the darkest of the dark arts of engineering. As a result, a 2012 DTM car should produce about 1,000kg of downforce at the rear wing. That's like having a Ford Ka perched over the back axle. And that figure doesn't even include the effect of the diffuser. That's the big tray that stretches for 2m under the car - half the length of the vehicle - channelling air under the belly of the beast to aid stability. Because the diffuser is so long, it should make the cars very balanced around their centres.
Yet despite all those wings, there is actually less aero-induced grip than last year. Less aerodynamics means a greater reliance on ‘mechanical' grip - instead of relying on the wings to stick the car to the track, the drivers will be depending on the tyres. And that means the holy grail of motorsport - more overtaking. If the car in front isn't ‘stealing' as much of your downforce - and therefore grip - then you can get closer in faster corners. The 2011 cars were on the edge, especially in qualifying, but because the Hankook tyres are larger than the Dunlops used last year, the cars should be more stable.
Is there anything Gary Paffett, Merc's leading driver, would change? "I wish we had more power. That would make it more interesting because of the extra mechanical grip." Sorry, Gary - you want more power? The 4.0-litre V8, revving to 8,500rpm and producing about 500bhp in a car weighing 1,050kg, isn't enough for you? No, you're right: 0-62mph in about 3.0seconds and a top speed approaching 200mph is a tad sluggish.
There's other deliciously trick stuff as well. All the cars are fitted with a brake cooling system, so when the driver comes into the pits for a tyre change, they can press a button on the steering wheel that dumps water onto the brake disc, as they are no longer being cooled by air alone.
Re: DTM 2012
Messaggio da LuFo R » giovedì 15 marzo 2012, 17:26
letto l'articolo su topgear dello scorso mese... che roba. :amore
Voglio i fender come quelli dell'audi. :amore
Re: DTM 2012
Messaggio da delta08 » giovedì 15 marzo 2012, 17:44
che faigata ... tre macchine UGUALI :amore :asd
" The 4.0-litre V8, revving to 8,500rpm and producing about 500bhp in a car weighing 1,050kg, "
:amore :amore :amore :amore
Re: DTM 2012
Messaggio da DOK85 » giovedì 15 marzo 2012, 17:57
porca trota non sò qual'è la più bella :amore
Re: DTM 2012
Messaggio da maialedacorsa » giovedì 15 marzo 2012, 18:27
sono curioso di vedere come andrà la bmw :amore
su reti "normali" sicuramente non lo faranno vedere :(
Re: DTM 2012
Messaggio da Acid » giovedì 15 marzo 2012, 19:39
delta08 ha scritto:che faigata ... tre macchine UGUALI :amore :asd
bèh, diciamo che con i pezzi che hanno in comune, oltre a ridurre il costo del 40% ( :stica ) darà anche un pò più di competizione tra di loro. anche vero che favorisce la bmw, che torna quest'anno
Re: DTM 2012
Messaggio da eddy » venerdì 16 marzo 2012, 0:22
vabbé a sto punto facevano un monomarca e cambiavano solo l'emblema! :sese
vi ricordate il DTM di 10 anni fa?
o meglio ancora, di 20 anni fa?
:sigh
Re: DTM 2012
Messaggio da AleVtec88 » martedì 20 marzo 2012, 2:10
i tempi cambiano purtoppo..
aumentano i costi e x contenerli fanno ste cose..
10 15 anni fa c erano un sacco di marche e si bastonavano! :amore
Re: DTM 2012
Messaggio da eddy » martedì 27 marzo 2012, 16:58
YOSHI EG9
Re: DTM 2012
Messaggio da YOSHI EG9 » martedì 27 marzo 2012, 21:00
AleVtec88 ha scritto:i tempi cambiano purtoppo..
ed infatti per me sono stronxate i regolamenti buttati giù a casaccio per "limitare" i costi! :azz
Quei 3 aborti,oltre che essere dei prototipi che nulla hanno a che fare con le auto di serie,praticamente sono gemelle.
Se vogliono contenere le spese,basta che fanno come una volta:il modello che corre deve essere prodotto in un tot. di esemplari,omologato e venduto al pubblico. :teach
Un alto numero minimo di esemplari richiesto sommato a numerose limitazioni per la circolazione stradale garantiscono automaticamente la riduzione delle cifre in ballo! :good
Re: DTM 2012
Messaggio da Acid » mercoledì 28 marzo 2012, 8:43
seguendo questo ragionamento, possiamo anche eliminare almeno il 50% dei campionati fatti in tutto il mondo.
Re: DTM 2012
Messaggio da skyturnedred » mercoledì 28 marzo 2012, 10:58
infatti basterebbe tornare ad un dtm fatto di auto di serie, con motori, schema sospensivo e dimensioni esterne come da relativa auto di produzione...Certo andrebbero meno di questi prototipi camuffati, ma il marchio avrebbe un ritorno e la gente tornerebbe a tifare per i propri beniamini. Anche se mi pare che in germania faccia cmq un botto di ascolti anche così...
YOSHI EG9
Re: DTM 2012
Messaggio da YOSHI EG9 » mercoledì 28 marzo 2012, 16:29
Acid ha scritto:seguendo questo ragionamento, possiamo anche eliminare almeno il 50% dei campionati fatti in tutto il mondo.
una volta rally,superturismo e company derivavano tutti da modelli prodotti di serie per regolamento:spettacolo e spettatori ringraziavano! :sisi
A volte poi,lo spettacolo era anche troppo..... :daniel
Poi grazie a ciò,nacquero un sacco di bei gingillini per divertirsi in giro! :good :lecca
Delysid.it
Re: DTM 2012
Messaggio da Delysid.it » mercoledì 28 marzo 2012, 16:40
Assolutamente si! Non è che ci perdiamo molto...
Prelude BB8 - 30.000 km
