Anche al sottoscritto dispiace la carenza di prestazioni,ma una mini carriola a motore centrale la tirata fuori dal cilindro solo la mammahonda.
Non hai mai avuto una MX-5con una mx5 se vuoi ci vai in vacanza in coppia.
hai interpretato malecon un po' di sacrificio con una mx5 se vuoi ci vai in vacanza in coppia.
Di quale serie di MX-5 parla, però ?Michel_ITR99 ha scritto:Non hai mai avuto una MX-5con una mx5 se vuoi ci vai in vacanza in coppia.![]()
If you’re 180cm tall like yours truly, the top of your head will sit inches clear of the window sills, meaning a drive will mess up your hair, a crash will send your face into the windscreen frame, and a downpour will require you to remove several vertebrae to fit beneath the targa-style roof.
The tiny engine sounds like a tortured blender, and sensationally spends 99 per cent of its life screaming between 3500-6000rpm – the mark of a true Honda motor.
Honda has decided that the diminutive S660 roadster that’s sold in Japan would not have a broad enough appeal to justify homologation in other markets. Hachigo said: “If there is strong demand from a region then we will always consider possibilities, but the S660 is a car that was developed for the Japanese market and we’d have to do a lot of work on it to make it comply with European regulations. I also wonder: would a car like this, sold in Asia, succeed in Europe?”
