S2000 club racer , l'ultima s2k
void
Messaggio da void » giovedì 5 aprile 2007, 8:35
The club racer-inspired 2008 Honda S2000 CR Prototype making its world debut at the New York International Auto Show introduces a higher level of track-worthy performance and style to the S2000 roadster, American Honda Motor Co., Inc., announced today.
The S2000 CR will be available as an entirely new S2000 trim level when it goes on sale in the fall of 2007. The lighter, stiffer and more aggressive overall design is engineered to maximize the S2000's potential on a racetrack with the goal of substantially-improving track times, chassis balance and feel. The factory-tuned roadster provides highly-aggressive suspension settings, increased body and chassis rigidity, overall weight reduction and an aerodynamic body kit dialed-in for reduced lift. An aluminum hardtop replaces the convertible soft top as standard equipment.
"The S2000 CR is the closest thing you can get to a Honda-built racecar with license plate holders and a horn," said John Mendel, executive vice president of American Honda Motor Co., Inc. "Its features and equipment are designed to appeal to weekend club racing enthusiasts."
The full-body aerodynamic package reduces lift through large and highly-tuned front and rear spoilers. Exclusive chassis features include a quicker steering ratio, Bridgestone Potenza RE070 tires, a wider rear tire size, firmer springs and dampers, larger stabilizer bars and a new wheel design in a dark gray color.
Substantial structural bracing has been added to the storage area previously occupied by the soft top, resulting in additional rigidity. The aluminum hard top replaces the soft top of the conventional S2000, resulting in an overall weight savings of approximately 90 pounds when removed (relative to the current S2000).
The exclusive interior is highlighted by unique cloth seating surfaces with yellow stitching, a unique spherical aluminum shifter and carbon fiber-style trim panels. Air conditioning and an AM/FM Stereo with CD player are optional equipment. Standard features for the S2000 include 17-inch aluminum alloy wheels, ABS and Vehicle Stability Assist (VSA). While VSA serves to effectively enhance driver control during acceleration, braking, and cornering, the system can be disabled with the touch of a button when conditions warrant it.
Widely considered the quintessential roadster-style sports car, the S2000 is the performance icon for the Honda brand and combines uncompromising racetrack-ready performance with everyday usability. The S2000 rewards driving enthusiasts with a potent 2.2-liter, 16-valve DOHC VTEC? 4-cylinder engine and a precise, short throw 6-speed manual transmission, along with tenacious handling and a perfect 50/50 weight balance.
The renowned high-revving engine delivers 237 horsepower at 7,800 rpm and 162 lb-ft. of torque at 6,800 rpm. Perfectly complimenting the engine's output characteristics is a compact, longitudinally-mounted, close-ratio 6-speed manual transmission that features a direct linkage for precise shifting and quick throws. Combined with a front and rear double wishbone suspension, precise electric power steering, and a torque-sensing limited slip differential, the end result is a complete, no compromise, performance package for the enthusiast driver.
qui trovate le foto
Iceman
Messaggio da Iceman » giovedì 5 aprile 2007, 8:59
:sbonk :sbonk :sbonk
ha perso si e no 40kg un casso...
roBBBBa fatta per gli americani e basta...
HD
Messaggio da HD » giovedì 5 aprile 2007, 9:09
Iceman ha scritto::sbonk :sbonk :sbonk
Per me invece 40kg sono TANTI e mi piace che la Honda sia race oriented... ;)
Poi levi lo stendibiancheria dietro e il paraurti terone ed è perfetta...
Saranno utilissimi eh, non lo metto in dubbio, ma sono orrendi.
Belli invece i "cosi" dietro il rollbar...
Looka
Messaggio da Looka » giovedì 5 aprile 2007, 10:09
stupendo il kit, stupenda l'idea, stupendo il colore, inguardabili i cerchi :good
brava honda :clap
GIMME A HELL, GIMME A YEAH!
Giacomino
Messaggio da Giacomino » giovedì 5 aprile 2007, 10:54
LookaHCI ha scritto:stupendo il kit, stupenda l'idea, stupendo il colore, inguardabili i cerchi :good
brava honda :clap
Tamarro :teach
Pare che sul cicuito di prova della Honda abbia girato più forte di 2 secondi rispetto alla "normale", e per normale suppongo si riferiscano al 2 litri...bah... :sosp
Messaggio da Acid » giovedì 5 aprile 2007, 11:00
l'f20c è disponibile solo in europa
america e asia hanno f22c
Danny7
Messaggio da Danny7 » giovedì 5 aprile 2007, 11:22
Beh ma per quello non servono alettoni e paraurti inguardabili...
Basta cambiare gomme,infatti non mi pare proprio abbia le RE050 che si trova di norma.
Messaggio da Mick Doohan » giovedì 5 aprile 2007, 11:26
mi sembrano le RE070 come sulla Civic TypeR JDM
Giacomino
Messaggio da Giacomino » giovedì 5 aprile 2007, 11:32
Mick Doohan ha scritto:mi sembrano le RE070 come sulla Civic TypeR JDM
yesssssssssss
In ogni caso, dipende dalla pista, 2 sec si possono tirar giù solo di gomme, appunto, non mi pare tutto sto "track oriented"...o magari sono io che non capisco una ceppa...
HD
Messaggio da HD » giovedì 5 aprile 2007, 11:39
sono anche quelle della Scooby le RE.
Quindi sterzo più diretto, ammo e molle più dure e barre antirollio maggiori di diametro.
E in più una spece di duomi posteriore.
I 40kg (o poco più) di alleggerimento si riferiscono solo al sof top
Messaggio da Mick Doohan » giovedì 5 aprile 2007, 11:51
yesssssssssss
Speriamo che le importino pure da noi, sarei curioso di provarle (assieme alle RE01R), visto che poi dal sito jap della Bridgestone sono state tolte le RE040.
Messaggio da Acid » giovedì 5 aprile 2007, 11:52
la cosa più oscena in assoluto è il paraurti anteriore
:vom
Ultima modifica di Acid il giovedì 5 aprile 2007, 11:53, modificato 1 volta in totale.
Engo
Messaggio da Engo » giovedì 5 aprile 2007, 11:53
tutte le S dal 99 ce lhanno di serie la duomi posteriore :teach
Daniel M
MembroZ RedentoZ
MembroZ RedentoZ
Messaggio da Daniel M » giovedì 5 aprile 2007, 12:02
Dovrebbero aver aggiunto altre barre al posteriore! ;)
CMQ, bella, cerchi inguardabili (sembrano dei alessio), l'alettone lo pitterei di nero.
Iceman
Messaggio da Iceman » giovedì 5 aprile 2007, 12:47
io sulla mia ho tolto si e no 40kg senza problemi :imba
poi è alta come un SUV :sbonk
Iceman
Messaggio da Iceman » giovedì 5 aprile 2007, 12:48
brava honda :clap
Tamarro :teach
beh se l'altra montava gomme stradali e questa Semislick ce una bella differenza... :teach
ne dubito rispetto al F20C :sbonk
Iceman
Messaggio da Iceman » giovedì 5 aprile 2007, 12:50
Danny7 ha scritto: Beh ma per quello non servono alettoni e paraurti inguardabili...
sono quelle :teach
andre82
Messaggio da andre82 » giovedì 5 aprile 2007, 13:22
http://www.autoblog.it/post/7872/salone ... a-s2000-cr
mmmmm
non mi dice nulla!
son capaci tutti a togliere 40kg togliendo clima capotte e radio!
Giacomino
Messaggio da Giacomino » giovedì 5 aprile 2007, 13:39
HDriver ha scritto: I 40kg (o poco più) di alleggerimento si riferiscono solo al sof top
Naaaaaaaaa
molti di meno se ne levano togliendo il meccanismo della capote, i dati specifici ce li ha psychicy, ma parliamo di pochi kg. Peraltro, non penso che l'HT sia in carbonio.... :angel
TACCA
Messaggio da TACCA » giovedì 5 aprile 2007, 13:44
a parte il colore, hanno rovianto una macchina, comunque va bene così....almeno le prime serie saranno le più ricercate, le VERE S :asd :asd :asd
sciao beli
