Nuovi pulsanti del tunnel centrale ora con switc per il Tasto VSA (controlla di stabilità)
Nuovo disegno dell'airbag, nuovo disegno dei cerchi
Indicatore temperatura esterna e headrest speaker di serie!!
The S2000 instrument panel was designed for quick reads at speed. As that bright digital tach arcs rapidly clockwise, you get an advanced lesson in acceleration. And the harder you prod the S2000 via its new Drive-by-Wire Throttle System, the more you realize this car was built to be worked over. It just loves the attention."
